Vacuum recommendation
/ Vacuum recommendation #1
tmshort
Indiana
All-
Am in need of a gas powered vac to clean leaves and debris from flower beds, around the pool, etc.
I need something portable / handheld, as there is not good access for something attached to the tractor.
Any recommendations - brand, model, etc?
Thanks in advance
T.
/ Vacuum recommendation #2
I needed a leaf blower to get the leaves out from the schrubs around the house and planted raised islands. Once I get them into the yard, I use the bagger on my lawn mower do the rest. I bought a Husquavarna model 125B, hand held blower last week. Found one at Lowe's for $139. 170mph with 420cuft/minute. Weighs @9lbs. It works very well for my jobs and it can blow the leaves through the yard with a little more work and time. It's also made as a leaf blower and vacuum with model number 125BVS for about $180. They give you a bag that attaches, it has a grinding setup inside, and it's supposed to have a 16 to 1 reduction by grinding the leaves up. My blower has been running well. I've ran a gallon of gas through it so far without it skipping a beat. You might think that's a lot of gas but it is actually good on gas. I've been just running it a good bit. All my many oak and maple trees are dumping their leaves. Stihl has one very similar but was a few bucks more. Redline, bought out by Husquavarna, has one almost identical but it costs a good bit more. Redline is their commercial brand usage models.
/ Vacuum recommendation #3
I use an Echo es-255 shred n vac. It has plenty of suction and it sheds almost everything It will suck up your mulch if hold it to close. I have had mine for 3yrs and I like it I have a small lawn care buisness and I use it every day
2007 Toyota Tundra 4x4 Ext. Cab Pickup Truck (A64556)
2007 Toyota Tundra...
2016 INTERNATIONAL PROSTAR 6X4 T/A DAY CAB TRUCK TRACTOR (A67147)
2016 INTERNATIONAL...
2017 Land Rover Discovery Sport AWD SUV (A64557)
2017 Land Rover...
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
HONDA generator (A64553)
HONDA generator...
KMC 18' FIELD CULTIVATOR (A64278)
KMC 18' FIELD...
