vaccine - curious question
/ vaccine - curious question #31
roxynoodle said:
I am a person for whom antibiotics were overprescribed for sinusitis.
Sinusitis is one of the more difficult issues in this whole business. Your case is actually quite atypical due to your trauma so what I am about to say does not apply directly to you.
There are, as N80 mentioned above, a few factors that make sinusitis such an issue. For starters, it is actually very difficult to diagnose accurately unless it is fairly advanced. The reason for that is that the symptoms of early or even moderately advanced sinusitis are virtually no different than the symptoms of an ordinary common cold. There are no easily performed laboratory studies that help distinuguish bacterial sinusitis from a cold and even xrays are fairly useless. The xray of someone with early to moderate sinusitis look virtually identical to the xray of someone with a cold. (Bizarrely, radiologists have no diagnostic code for common cold as a cause of these findings so inevitably report such findings as "consistent with sinusitis" which puts further pressure on the doc to treat) This is a big part of the problem. Physicians are confronted with perhaps half a dozen or more patients per day during the winter months who are complaining of prolonged cold symptoms. The docs know that at most 10% actually have a bacterial sinus infection but they have no good way to distinguish those from the others during a single office visit. Ideally they would take the time and educate patients (patient patients ;) ) and send just about all of them home without antibiotics but with the understanding that a few of them might need to be reevaluated in a few days, especially if symptoms are worse. Time pressure, economics and general patient expectations and even fear of malpractice conspire to convince the doc to prescribe an antibiotic "just in case". It is a slippery slope however as it soon becomes just "standard practice" to prescribe an antibiotic for just about anyone with cold symptoms (to a greater or lesser extent in many practices). There have been studies done in the US showing that up to half of all patients who have a discharge diagnosis of "common cold", a clearly viral illness, will leave the office with an antibiotic prescription. That's nuts. But, as pointed out, the way we got there was through a combination of factors that focus on both the doc and the patient being impatient and not wanting to wait for 90%+ of those colds to simply resolve with time. There was a very interesting study done on students at the University of Virginia about thirty or fourty years ago where a group was intentionally infected with a simple cold virus and then asked to keep a symptom log book. They almost all had typical cold symptoms for the first 4 or 5 days but what was really striking is that a full quarter of them continued to have cough and nasal discharge for up to three or four weeks before it finally resolved. So, it is actually "normal" to have those symptoms for much longer than any of us is happy about and they do eventually resolve on their own the vast majority of time. None of the students was treated for sinusitis and they all recovered without antibiotics but that was fourty years ago before "sinusitis" became a fad diagnosis (to be sure it is also a real dx but probably the vast majority of what is called sinsusitis is really just persistent cold symptoms in the USA). Today it is standard to consider someone with cough and runny nose for more than 10 days to have sinusitis. Clearly that set of criteria grossly overdiagnoses the problem but it is used and even shorter periods of time often applied in clinical practice. It's one of those connundrums where if you set the diagnostic criteria higher you'd miss some of the real cases and if you set it low (as we have) you end up "diagnosing" a lot of people with sinusitis who are really just getting over a cold.
There is surprisingly little good science showing that antibiotics are important in the management of what is typically diagnosed as sinusitis. Clearly in some cases (the real bacterial ones) it is critical but for the "average" case it is not so clear and most patients simply resolve the symptoms over time just as the students from UVa did. Essentially that is because what is being called sinusitis is really just the prolonged normal resolution of viral common cold symptoms. There is a huge industry surrounding sinusitis however as the pharmaceutical companies especially but some practicitioners as well, depend on continued over reaction and over prescribing. The phenomenon of diagnosing and treating sinusitis is really only about 20-25 years old in the is country. Before that it was a relatively uncommon diagnosis so there is pretty good evidence that this whole "sinusitis" thing is largely unfounded. Kinda like how in the 1950's every kid had his or her tonsils out until years later it became clear that if you did not take them out they eventually healed anyway and you avoided surgery....today we still take them out occasionally but much less often than before. Similarly ear infections were over diagnosed and over treated in the 90's and 90's and are now being less agressively managed. It will be a while longer before both public and medical practitioners are reeducated about the sinusitis business so we can anticipate continued pressure to prescribe and over prescribing for a while longer. Patients can help by simply recognizing that common cold symptoms persist for weeks, not days and by holding off on trips to the doctor unless they are getting worse after the first few days of a cold or they have a new symptom such as fever a week after the initial symptoms. The other important thing you can do is to drive tractors as much as possible thereby staying out of contact with other humans and thereby lowering your risk of acquiring a viral infection. :rolleyes:
/ vaccine - curious question #32
Since we are getting into long distance diagnosis :p , I will expand a little farther.
She was digging thru the closet when she felt a sharp sting on the back of the arm/shoulder area. Threw everything down and got out but never saw what stung her. This was Friday evening.
By Saturday afternoon, the spot was puffed up considerably. Redness all around and spreading across her shoulder. Even her eyes were a little puffy. Not really much lingering pain although the spot was tender. Not wanting to chance waiting until Monday to see her regular doctor, we went to a primary care clinic where she was given the tetanus shot and something for the allergic reaction.
By Tuesday, some swelling still present. Redness still present all across her shoulder even more than before and some rash breaking out. Went to her regular doctor. He gave her some other things including the steriods.
/ vaccine - curious question #33
IslandTractor and N80,
Thanks for such a great discussion. I HATE taking antibiotics since they seem to upset my stomach. zPac seems to work though.
I get pressured at work to go to the Doc to get "fixed".
So what I got out the conversation is, unless I'm getting worse, just ride it out. And that the symptoms may linger for weeks.
Did I get that right?
Later,
Dan
/ vaccine - curious question #34
You got it. :)
Each person knows their own body better than any physician can in a 10 minute office visit. If you are slowing getting better that is par for the course after a bad "cold". You may feel worse in the morning (clogged up feeling) but so long as you are basically getting a bit better each day there is very little additional help you can get from medication.
/ vaccine - curious question #35
When I (one out of one doctors surveyed) get an upper respiratory infection I take ibuprofen for aches, pains and fever, a decongestant for stuffiness and maybe a non-narcotic cough suppresant. I have a sample closet down the hall with nearly every brand name oral antibiotic and I don't touch them. For me, a cold almost always lasts for two weeks, just as IslandTractor mentioned. Even if it lasts a little longer I don't bother with the antibiotics. In my younger days I did raid the sample closet for antibiotics but over the years, if I looked at things objectively, I realized they never seemed to help.
And, as mentioned, even for many, if not most bacterial infections like sinusitis and middle ear infections and bacterial bronchitis, your body will take care of the problem without antibiotics, and probably even better than antibiotics. It just takes time.
So when these flare up, if you are concerned then see a doctor. But if he doesn't prescribe anything don't worry about it and don't think he is ineffective. He's determined that you probably don't need anything. If you get worse or symptoms persist, check back with him.
/ vaccine - curious question #36
Thanks for the discussion, docs, it was very informative. I have also had surgery twice on the sinus. The first time was 4 years after the accident to remove the mass of broken bones, a broken bone that was in my nasal passage and to ream out the sinus opening at the top of the maxillary sinus. 3 years later I seemed to be in as bad of shape and that catscan showed more broken bones in the sinus and that the opening that had been reamed out was collapsing, whether because it was weak structurally or due to the bacteria, it wasn't certain. The ENT removed the bones and put a new hole under the large fracture line hoping it would be able to drain then. I use saline nasal spray to try to keep it open and clean. Sometimes it helps and sometimes it doesn't. But, honestly, I really don't want any more holes so until I get to the point where I feel like my entire head is being crushed by vises in all directions, I just try to live with it. I have wondered if they could just go in and clean it out once in awhile instead of trying to create new sinus openings?
As a follow up. I calle done of my friends who is an xray tech in an er. he 'polled' some of the MD's there about tetanus. No one he asked had actually seen a case of tetanus, or heard of a case.. though all said.. that basically, it was very treatable, even after onset of the muscle spasms, due to advancement in meds.. like chemicals to reduce the spasm, as well as imune globulin, and good antibiotics, pain management.. etc. They basically said,.. that at least in the uS.. as long as you get into the hospital before you have stoppe dbreathing.. you will likely survive.. etc. I take it 3rd world countries don't have it so good.. med or cleanliness wise.
Soundguy
/ vaccine - curious question #38
Then too, a cockspur on a farm with horses is about as likely a tetanus vector as we're to find in a (at present) first world country.
/ vaccine - curious question #39
I don't recall where I heard this but here goes...
If you get cut once in a while by rusty metal or get dirt in the cut then you are getting "vaccinated" by being exposed to the rather common bacteria that caused tetanus.
So, no booster shot needed in this case and no worry of getting harmed.
Anyone heard this before?
/ vaccine - curious question #40
I don't guess I'd heard that, Rich. A few years ago, I was wearing sneakers (used to call them "tennis shoes") when I stopped to visit a neighbor and while there I went to help him load some cattle in a trailer and in the process, I stepped on a mesquite limb and one of the thorns went right through the bottom of my shoe and into my foot. Of course, all I did was pull it out and went on with what we were doing at the time. When I got home and took the shoe off, the sock and shoe were a bit bloody, but not too bad, but the next day I stopped by a doctor's office and got a tetanus shot. It's the only tetanus shot I can remember getting, and now I can't remember when that was; about 6 or 8 years ago though.
KJ K2223 23'x22' Metal Shed (A60463)
KJ K2223 23'x22'...
GMC 2500HD 4wd Service Truck (A61307)
GMC 2500HD 4wd...
2007 FORD F750 XLT SUPER DUTY SERVICE TRUCK (A58375)
2007 FORD F750 XLT...
John Deere 8R 280 (A60462)
John Deere 8R 280...
2012 JACK COUNTY TANK 130 BBL STEEL (A58214)
2012 JACK COUNTY...
2012 AMERITRAIL (A55745)
2012 AMERITRAIL...
