Vac
mmckim90
Brashear, MO
JI Case
What kind of diesel motor or gas motor can I put in my vac besides stock engine.
It will need the same little engine that factory put in it. The engine is part of the frame that holds the tractor together. I have 2 vac, and 1 va tractor. the va needs different engine, so a va or vac will fit. thats about the only choice that I know of. thanks; sonny580
WOW, they really made that vacuum part of the tractor then, it must be a special purpose tractor maybe for picking up leaves?..
Case made a model of tractor called a VAC, I suspect that is what is being referred to (given that we are in the Case section).
Aaron Z
Aaron Z
Right, here is a picture taken in 1945 of me "driving" Grandpa's Case VAC:
2008 INGERSOLL RAND G240-191KW GENERATOR (A63276)
2008 INGERSOLL...
2001 International 3800 School Bus (A64194)
2001 International...
2018 Kenworth T800 T/A Sleeper Cab Truck Tractor (A64194)
2018 Kenworth T800...
Bobcat Skidsteer Snowplow
Bobcat Skidsteer...
BRIGGS & STRATTON STORM RESPONDER GENERATOR (A64276)
BRIGGS & STRATTON...
2005 Freightliner Tropi-cal T396 39ft. Class A Motorhome (A64557)
2005 Freightliner...
