V519 / TL519 Compact Telehandler
/ V519 / TL519 Compact Telehandler
What gave you that idea?
/ V519 / TL519 Compact Telehandler #22
Website says it comes with something called the Bobattach or something like that...
Yep, that is the SSQA system and dimensions that other skid steer manufactures copied after the patents expired.
Same as what is on my V417, a lot stronger than the SSQA on a tractor:
Levers up:
/ V519 / TL519 Compact Telehandler #24
So, the Bobattach is the same as the SSQA? Cool! Was afraid that I would be locked into Bobcat implements only.
/ V519 / TL519 Compact Telehandler #26
It's a sweet looking machine. I'm wondering if they have aux. Hydraulics in the rear. I've asked my dealer to find me one to look at...
/ V519 / TL519 Compact Telehandler #27
They should do, but not sure. It's probably not standard though. EU version does, so US version should aswell I think.
Not from the factory over here. 👎
But it could be added. 👍
I wonder what it uses for a rear counterweight? It looks narrower than the V417:
And my V518 also had a big cast iron counterweight:
/ V519 / TL519 Compact Telehandler #29
I think more of the counterweight has been put on the inside of the machine, to increase visibility to the rear. Ask the dealer if you can get a orange cast iron weight mounted to the back of the V519. It can really increase lift capacity.
EU version TL26.60 is the same as V519. Another model is the identical TL30.60, but with 900 pounds extra lift capacity, which comes from that extra cast iron weight (as shown on image) and possibly some internal weights. I think you should be able to get the cast iron weight on your V519 aswell.
/ V519 / TL519 Compact Telehandler #31
Thanks for that info and the picture shows the hydraulic hitch.
Correction, it isn't hydraulic:
/ V519 / TL519 Compact Telehandler #33
Hydraulic is an option though. 4 versions of hitches: Fixed hitch, rotating hitch, rotating hitch with auto-locking (picture) and hydraulic pick-up hitch. Rear auxilliary hydraulics are an option but PTO and 3pt hitch aren't. I dont't think they would be that usefull anyways.
/ V519 / TL519 Compact Telehandler #34
Hi guys! First post here. I just bought a V519 a couple months ago for my construction company. I've been searching for other owners/reviews and stumbled across this forum/thread. I will say I am very impressed and happy with it. It has exceeded my expectations!
/ V519 / TL519 Compact Telehandler #36
I saw a question about the counter weight. I will have to inspect tomorrow but as far as I have seen, the very back space is taken up by the fuel tank. They must of gotten clever with the weight. I have lifted 88 sheets of plywood about 14' up in the air. One of my guys said it looked like the rear tires got light but I didn't detect anything from the operators seat. The thing is just a beast. I also took a pallet of sod and extended it all the way out to see how it would act. No problems.
:welcome: to TractorByNet! Congratulations as the first V519 owner on the first V519 thread on TBN. :thumbsup:
Thanks for the picture, keep 'em coming.
Looking forward to your updates on it.
/ V519 / TL519 Compact Telehandler #38
Thanks Xfaxman! I will post more pics after i get the kiddo to bed.
/ V519 / TL519 Compact Telehandler #39
One of the guys asked where the dust pan was.
Aluminum Set of Tool Boxes (A62613)
Aluminum Set of...
378908 (A61166)
378908 (A61166)
New/Unused Wolverine Quick Attach 72in Grapple Bucket (A65583)
New/Unused...
Ford Tractor (A62613)
2016 FORD F550 CREW CAB SERVICE TRUCK (A59905)
2016 FORD F550...
(15) Polyethylene Road Bed Protection Pads (A60462)
(15) Polyethylene...
