V BELTS
   / V BELTS #1
tractor21
Saint John
05 KabotaG2160
Hi. Got a 05 G2160.How do i get at the pto v belts up front to check/change. also how do i get enough room to change the battery. thanks.
   / V BELTS #2
To change the battery you need to pull the radiator screen out. The battery is a Group 51R (Honda car battery).
For belts there should be a sticker on side of frame that shows how to measure the stretch on the spring for proper tension. To remove belts you need to back of the belt tension adjustment and drop the front deck link and remove the bottom guard and the bracket that keeps the belts on the pulleys. Old belts usually come off easy but new belts will need to be threaded on one sheave at a time and clearances will be tight. Belts are easy to slip and burn up with the 60 inch deck and also somewhat with the 54. Have only had good luck with the Kubota sourced Bando belt set ($80 US) think the pulleys may be metric as Kubota USA also sells a set of B section belts but they are not as strong as the Bando belts. After installing the belts you need to tension according to directions and check after some mowing and re tension as they will loosen up some after break in.
David Kb7uns
   / V BELTS
thanks for the info.so far the belts are ok using the blower but nothing lasts forever.
1275 (A50490)
1275 (A50490)
MAJOR LOT NUMBER 260 (A53084)
MAJOR LOT NUMBER...
UNUSED HURRICANE G350 MINI CONCRETE MIXER (A51248)
UNUSED HURRICANE...
2007 Ford Ranger Pickup Truck (A51692)
2007 Ford Ranger...
2008 Chevrolet Impala Sedan (A51694)
2008 Chevrolet...
2011 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2011 Ford F-150...
