V belts for 44 inch JD/RAD 2 stage snow caster
   / V belts for 44 inch JD/RAD 2 stage snow caster #1
leonz
Super Member
NE USA
JD LA115, WH 244, Troy Built Horse 8 HP
Would any of you happen to know where john Deere gets its gag, cough, wheeze, hack, very expensive ($150.00)
V belts for its RAD 44 inch snowblowers for the LA series????
I really do not want to have to have the guide pulleys and the impeller pulley machined to receive an A117 belt.
Thanks much.
   / V belts for 44 inch JD/RAD 2 stage snow caster #2
Leon,
What's the JD part number for the belt? Is it M174506?
   / V belts for 44 inch JD/RAD 2 stage snow caster #3
leon, is #34 (long belt) the one you're after? Deere#m115885,
if so, I'm sure the dealer isn't telling you that they offer it in a lower priced belt through two companies they on control of A&I and Sunbelt,
see part numbers and price relation in second picture
Joe
Toro Workman MDX Utility Cart (A51691)
Toro Workman MDX...
RYOBI 2900 PSI GAS PRESSURE WASHER (A51248)
RYOBI 2900 PSI GAS...
23222 (A50323)
23222 (A50323)
1/8" X 41" W X 81"L DIAMOND PLATE STEEL SHEETS (A51247)
1/8" X 41" W X...
378811 (A51573)
378811 (A51573)
ECHO SRM-2120 GAS WEED EATER (A51248)
ECHO SRM-2120 GAS...
