V belts and flail mowers
   / V belts and flail mowers #1
leonz
Super Member
NE USA
JD LA115, WH 244, Troy Built Horse 8 HP
AS mowing season is just around the corner for most of us I thought I would
upload these images for everyone to use.
NOT name dropping here:
The Gates V belt tensioner is easy to use and is available from
rockauto for 22 and change plus shipping(an example internet retailer)
When you tension new or old belts on the Caroni flail mowers be mindfull of the snubber pulley WHERE:
When the belt is tensioned the flat portion of the belt it should not have anymore tension than 1/64" PER INCH OF SPAN BETWEEN THE UPPER PULLEY AND THE LOWER PULLEY.
SO if the span is 8 inches between the center lines of BOTH PULLEYS the V belt will have no more deflection than 8/64" of an inch or 1/8 of an inch (as an example).
The screw adjustment for the V belt drive eliminates a moveable tension pulley but the issue of proper belt tension remains.
I hope the Caroni folks change over to a spring tensioned flat snubber pulley and will also offer a retrofit kit for the mowers already in service.
If they had a sticker glued to the inside portion of the belt guard illustrating the proper tension distance behind the V belt that would be an excellent addition.
The folks with flat spring tensioning snubber pulleys only have to worry about the belts
condition-please see the explanation below.
If your B section belts are flaking rubber dust off in your hands
and you see cracks in the base of the V belt it is time to toss them in the
trash or recycle them.
Happy Mowing and do not hesitate to eliminate ant hills and puff balls while mowing,
AND plase for your own safety carry wasp and hornet killer at all times in the
tool box and also in the cup holder.
New Skid Steer Attachment Plate (A53002)
New Skid Steer...
2021 ALLMAND BROS, INC. NIGHT LITE TOWER (A52472)
2021 ALLMAND BROS...
2020 Steiner 450 Slope Mower (A51573)
2020 Steiner 450...
2011 INTERNATIONAL PROSTAR TANDEM AXLE SLEEPER TRUCK (A52577)
2011 INTERNATIONAL...
Case IH 3408 8 Row Corn Head (A52349)
Case IH 3408 8 Row...
Caterpillar 56in Excavator Bucket (A51691)
Caterpillar 56in...
