V-belt Power Transmission calculations.
   / V-belt Power Transmission calculations. #1
Iplayfarmer
Super Member
Idaho
Massey Ferguson 1215, Case 801B
Is it reasonable to expect a single 1/2" v belt going around a 4.25" pulley to transmit 7 horsepower?
I modified my old Terratrac GT30 with a F140 continental engine to drive an aftermarket hydraulic pump with a v-belt. It runs great until I get a heavy load in the bucket. Then it squeaks. This is a crawler loader with a front end loader instead of just a blade. The belt slips somewhere between 500 and 1000 PSI. The loader still runs fine, albeit slower.
I calculated my 6 gpm pump running at 2000 psi would take 7 horsepower. Before I continue troubleshooting the existing system I figured I should ask if it's underdesigned. If the belt is just not capable of transmitting that much power, then I need to redesign rather than optimize this current system.
   / V-belt Power Transmission calculations. #2
I'd move up to a B belt or double the A size if sheaves have room and/or can be replaced.
A spring-loaded vs fixed tensioner may be of help with any configuration, esp if positioning can guide a belt around more of the smaller pulley.
   / V-belt Power Transmission calculations. #3
Bely mfgrs. like Gates, publish that data in their belt catalogs, both the belt rating and the minimum shev diameter.
I tried figuring it out through the Gates online stuff, but I ended up calling their engineering support number. I can't say enough good about their technician who answered the phone. It took all of about 90 seconds for him to tell me that my configuration was good for 4 horsepower, but that a Predator style belt could get me up to 9 hp. I have a predator belt on order from the local dealer, and I ordered one size larger of a pulley, too. The larger pulley not only gives me a better torque advantage, but it gives me more contact area with the belt. Both should increase the amount of horsepower I can deliver to the hydraulic pump. It will reduce the maximum gpm some, but I'm willing to give up a little flow to get the pressure up.
2013 Infiniti M37 Sedan (A53424)
2013 Infiniti M37...
Galvanized Livestock Gates - (5x Gates) (A55218)
Galvanized...
UNUSED DIGGIT HEAVY DUTY 20'X20' ALL-STEEL CARPORT (A54757)
UNUSED DIGGIT...
2009 Hino 268 Progress VTA72 1500 Gallon Vacuum Truck (A51691)
2009 Hino 268...
2023 54' Hooklift Dumpster 15 Cubic Yard (A55788)
2023 54' Hooklift...
2015 Ford F-450 Crew Cab Knapheide Service Truck (A55788)
2015 Ford F-450...
