Utra low sulfur VS High sulfur dyed ?
   / Utra low sulfur VS High sulfur dyed ? #31
I don't want to mess up a new tier 4 engine and as my wife calls it a $17k lawnmower
Your tractor, I mean $17K lawnmower (props to your wife for comedy), has a Tier 4 interim engine, same as most compact and subcompact tractors have had since about 2008. It's not one of the recent Tier 4 final engines (which are only required over 26HP). So don't worry about the Tier 4 final issues you may have been reading about.
Last question. I had the dyed 15ppm ULSD #2 delivered today. $2.14 @ gal.
What is the difference of dyed 15ppm ULSD #1 other than the price ?
And is the #2 ok for the Tier 4 engines?
   / Utra low sulfur VS High sulfur dyed ? #34
ULSD #2 is diesel and is what a tier 4 tractor runs on.
ULSD #1 is sometimes called kerosene or at the pump may be called #1 diesel. In cold country #1 or #2 can be used for diesels.
I run #2 year round with Power Service additive to prevent fuel gelling. I usually don't have that problem with the tractor kept in a garage in winter when not in use.
ULSD #2 is diesel and is what a tier 4 tractor runs on. ULSD #1 is sometimes called kerosene or at the pump may be called #1 diesel. In cold country #1 or #2 can be used for diesels. I run #2 year round with Power Service additive to prevent fuel gelling. I usually don't have that problem with the tractor kept in a garage in winter when not in use.
Thanks,
I believe I know all I needed to know about the #2 dyed diesel & #1 diesel/ kerosene. But wait!.... Last week I bought K1 kerosene at $5.99 per gal. Can I safely use #1 dyed diesel for a portable kerosene heater?
   / Utra low sulfur VS High sulfur dyed ? #36
Thanks,
I would say yes. My portable kerosene heater (salamander) can use #1 or 2. There was a sticker on mine when I bought it that said to use #1 or 2 fuel. K1 around here is high in price also. I use #2 in mine and it runs fine.
   / Utra low sulfur VS High sulfur dyed ? #37
This is still confusing to me as well. Local stations can't seem to tell me that their dyed fuel is ULSD. Their pumps have stickers as follows:
As a result, I'm still buying on road diesel.
   / Utra low sulfur VS High sulfur dyed ? #39
Thanks,
you've done well beyond the call of duty on this fuel topic....hopefully you can rest better at nightfall given responses.... best regards to ya & use of machine. btw have you decided on a fuel supplement or going as is since you're so concerned on fuel quality? there is never a lack of opinion on this topic... :)
I got a gallon of stabil for diesel. It's supposed to cover pretty much everything.
Sent from the mountains
2020 Polaris Ranger 1000 4x4 Utility Cart (A51691)
2020 Polaris...
New/Unused CFG Industrial MX12RX Mini Excavator (A51573)
New/Unused CFG...
40FT Shipping Container (Modified for Parts Storage) (A51573)
40FT Shipping...
2017 International Prostar Sleeper Truck Tractor - Cummins ISX 15 Engine - 10 Speed Eaton Fuller (A53472)
2017 International...
