utility vehicle for mowing
/ utility vehicle for mowing #1
JWB53
07 toolcat
i've been looking at bobcat toolcat to mow 40 acres, but 50,000 is a lot, is there another uv that i could consider, i do like the 90 inch deck option on the toolcat but will consider pulling a deck to save $ thanks
/ utility vehicle for mowing #2
If you change your mower the world is your oyster.
/ utility vehicle for mowing #3
If your going to mow 40 acres, I would consider an 85-90 pto hp tractor with MFWD (40-50K) and 15' batwing mower (14K). It will still take several hours.
The only UV really design to mow would be the Bobcat UV with mower mounted on the front. You could buy a pull behind mower (self powered) to pull behind any UV. However, it would probably take 2-3x as long as the toolcat. Toolcat will still take several days to mow. I don't believe either the toolcat or UV is a realistic/reasonable way to mow 40 acres.
/ utility vehicle for mowing #4
I agree with radman1, don't believe the toolcat or the UV is the answer for 40 plus acres.
:confused:
/ utility vehicle for mowing #5
Batwing
I was mowing 40 acres with my 4720 and a 6' mower. Middle of summer 05 - I went down and bought a JD 5525 cab with a 15' batwing. I used it today and the payment does not seem so bad when it is 100' outside...
D.
2020 KENWORTH T880 DUMP TRUCK (A65054)
2020 KENWORTH T880...
2023 JOHN DEERE 450P LGP CRAWLER DOZER (A64279)
2023 JOHN DEERE...
2021 Big Tex 14ET 18' Tandem Axle Trailer (A62679)
2021 Big Tex 14ET...
2001 WESTERN STAR  4900E (A65643)
2001 WESTERN STAR...
350 Block Engine (A65579)
350 Block Engine...
2022 Sany SY215C Hydraulic Hammer (A62679)
2022 Sany SY215C...
