Utility trailer for behind tractor
   / Utility trailer for behind tractor #1
teeravis1
Central Wisconsin
JD 4044R
I am looking at getting this 2 ton tandem floating axle utility trailer from country manufacturing for behind my b3030 Kubota for firewood, leaves, and anything else I can use it for:
http://www.countrymanufacturing.com/wagons.htm
Does anyone know of anyone with it or something similar and how they like it? I also looked at the Muts utility trailer and boski trailers also but liked this the best. Your thoughts would appreciated with the pros and cons you see with what I am looking at. - thanks
   / Utility trailer for behind tractor #2
CMI Utility Wagons & Trailers for atv and lawn and garden.
I'm guessing that you want the dump ability? Can't speak to that.
I have a Big Tex single axle 5x10 with 18" metal sides. I use it with my much smaller BX and suitable RTV1100 with no issues. It doesn't dump though.
I'm over weight for the tractor, but it works with some caution.
   / Utility trailer for behind tractor #3
I have yet to buy a compact tractor or UTV, but I have been looking around for a compact, tandem-axle, dump trailer as well. There are quite a few in Canada, all of which look to be made pretty well, but shipping into the US is very high, between $250 and $450! I called about information on the Country Manufacturing 7500 1-ton. They sent me a brochure, then I called for a quote on the 7500 Dump Trailer, 3010 hand-operated hydraulic dump, and the 2" ball hitch conversion kit. Shipping to my place is $124, which only made the full price $811 in the end, which I was very happy with.
Companies in Canada which I have found:
John BM Mighty Dumpers
QualiPro ATV Trailer Log Loader Woodlot Equipment and Logging Equipment Canada USA Ontario Alberta Used to have a conversion trailer from dump box to log bed, now they only have the log bed option.
MUTS MUTS - Multi-Use Trailer System for your ATV, Quad and 4 Wheeler I guess you said you already found this.
Pronovost Pronovost- Dump trailers - Off-road service
Normand Company Normand - Farm Dump Trailers
ES Martin Company Normand - Farm Dump Trailers
US Companies:
Country Heavy duty tandem axle ATV trailers for off road use by Country ATV
Agri Fab www.agri-fab.com - Tandem Axle Steel ATV/UTV Dump Cart ? 1,000 lb. Probably not the best quality...
Putnam Bogie ATV Trailer | ATV Trailers | Putnam Bogie ATV Trailer
Bosski 1600 Utility ATV Wagon - Power Dump Cart, dumping ATV Trailer- Power RAM strongest, best, ultimate atv farm trailer, atv ranch trailer
Last Frontier Last Frontier Trailers They are in Alaska, but the only one they might be able to ship to the states is their neatest one, the belly dump trailer.
Bailey's Bailey's - ATV Tandem Log & Dump Trailer Pretty neat, since you can easily convert from dumping to logging.
King Kutter King Kutter Incorporated
I personally don't like the big ATV balloon tires, but that is just me. I have sent in for information for many of these companies, so if you have any questions, please ask. The trailers that are at the top of the list for me are the Country, Bailey's, and King Kutter. You can call Bailey's for a free catalog, 1003T brochure, and video. I really like how the trailer is easily interchangeable, but no hydraulic dump. Although, the tongue is connected to the trailer, so you could chock the wheels, the reverse your prime mover to dump it. I have heard lots of good stuff about the King Kutter. Hand operated hydraulic dump, a great 47 degree dump angle, and a 3000lb. capacity. My local New Holland or John Deere dealer could get me something from John BM as well through Cummins and Bricker for a pretty good price. I have really had fun researching this stuff, so please let me know if you have any questions. BTW, I work at a Steiner, Ventrac, Grasshopper, Gravely, Ariens, Echo, Redmax, etc. sales and service place. My original thought was to get a tandem axle dump trailer to pull behind a Steiner or Ventrac, but I have heard that since they are articulated, any downhill grade would push the rear half of the tractor. And they are hydrostatic, so the transmission would go so after a couple of years on the hills in woods at the place I want to buy. Ok, enough for now.
BUSH HOG 7007 LOT IDENTIFIER 28 (A53084)
BUSH HOG 7007 LOT...
2018 Ford Transit 250 Cargo Van (A51692)
2018 Ford Transit...
2013 Dodge Charger Sedan (A52377)
2013 Dodge Charger...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
WESSEX CRX 240 LOT IDENTIFIER 265 (A53084)
WESSEX CRX 240 LOT...
