utility plow mount for a 3pt hitch on compact tractor?
   / utility plow mount for a 3pt hitch on compact tractor? #1
mach
hey guys, I'm looking for some design help on building a plow that will use my compact 1710 ford (20 hp diesel) 3 point hitch. What i want to build is a mount, that will allow me to change / build different shape of plow heads, rakes, root cutters, ect. If i can come up with a basic design, i could build / design my own cutting tools, to pull behind my tractor. For instance, i could bolt on a sod buster disc, or unbolt it and bolt on a root cutter blade, or build me a square tipped plow for digging footers, or digging ditches for pipe. So, basically, i want a tool that will use my tractors 3 point hitch, yet allow me to bolt on different tool heads/ blades.
Thanks guys,
Mach
   / utility plow mount for a 3pt hitch on compact tractor? #2
Hi mach not to long ago I was looking at a middle buster in the TSC catalog. Anyway just looking there may give you a few ideas for a 3Ph plow type frame that would accept different tools...
...but if you have a welder I think it would be better to have multiple 3ph frames instead, mostly cause because the angle it makes ground contact.
It sounds like you have a plan and may be on to something ...so I dunno. Good luck, can't wait to see what you come up with.
   / utility plow mount for a 3pt hitch on compact tractor? #3
Maybe I read it wrongly, but I think you are describing what I understand to be called a "tool bar".
If you do a search for that it might give you some ideas, change your mind, or change your direction - slightly or significantly.
   / utility plow mount for a 3pt hitch on compact tractor? #4
seems counter productive to me... the main claim of the 3pt beside drafting properly is convenience. You lose all of the above with a compromised design. A little more steel pays for a lot of time to do other things. Make each as a separate tool would be my suggestion.
   / utility plow mount for a 3pt hitch on compact tractor? #5
Mach, if you pursue this consider setting up the frame with a square tubing socket similar to a trailer hitch. This would make it much easier to change out the plow tools.
Otherwise I agree with others that it would be better to have separate implements and may be necessary in some cases anyway.
Steve
   / utility plow mount for a 3pt hitch on compact tractor? #6
I have been building my own plows for years. I have a 5' roto-tiller that I use to break my ground, it leaves my entire garden tilled and ready for my light equipment.
I started building different attachments that would work from my trailer hitch reciever tube. It works like a 140 Farmall "quick hitch" that is a 1 prong fast change type reciever only my reciever is a 2" I.D. trailer reciever. When I want a new tool I get a piece of 2" tubing, slide it in and build off of that. I don't have to build the 3point hook-up each time, the reciever hitch is already built. And it make it easy to change by pulling 1 pin and sliding a new one in.
For a middle buster to lay off rows, I used a "C" tine from a cultivator that had a hole in it to mount my plow. I can carry it with 2 fingers and change it out in 15 seconds. You can also mount a sweep on the same c-tine if you need that. You can also buy old mule drawn plows at an auction usually for 5-10 bucks, adapt the end where the mule was attached with a piece of tubing and take the handles off. Our smaller 20 hp tractors really don't produce enough power to tear up the old mule plows. They are lightweight but I use them with a YM2200 tractor, works great.
For a cultivator, I took all the steel from a mule drawn "spring harrow" that had c-tines and seperated the steel into 2 sides. I mounted each side on a piece of 2 inch tubing that was dropped about 9 inches so the reciever hitch would travel over the plants but allow the rakes to run along side of the plants. It works great. I made each side to slide in or out to be adjusted to how wide my plants were.
I needed a rake to rake up old winter wheat after bush hogging so I took the hay rake teeth and bar they were bolted to out of a mule drawn hay rake, welded the tubing to it and in just an hour or so I had a hay rake on my Yanmar.
I have a small 40' X 40' garden, no weeds or grass and only have about 2 hrs "hoe" time involved. I still pull the dirt to small plants with the hoe. My home made equipment is working well.
I built a 6' yard rake using hay rake teeth. I got my ideas off of this forum. I also built this to work from the reciever tube. It also does a good job. Beats the crap out of a hand rake.
   / utility plow mount for a 3pt hitch on compact tractor? #7
I can sort of visualize what you have done, but if you have photos that you could upload to this forum, that would be much appreciated.
2014 Ford Taurus Sedan (A56859)
2014 Ford Taurus...
(APPROX. 20) 4' X 8' X 3/8" SHEETING (A52706)
(APPROX. 20) 4' X...
2016 Hyundai Sonata (A56859)
2016 Hyundai...
25ft Tag Trailer (A56435)
25ft Tag Trailer...
2003 McCormick XTX 185 XtraSpeed Tractor (A56435)
2003 McCormick XTX...
New/Unused CFG Industrial QK16R Mini Excavator (A57453)
New/Unused CFG...
