Oil & Fuel UTF at Kioti Dealer
   / UTF at Kioti Dealer #51
On the web site it said that was for 2 2.5 gal jugs @$69 and a single 2.5 gal jug is $35. Good if you need between 5 and 7.5 gals; interestingly enough a single 5 gal pail is $77.
There is a $10.00 rebate on the 5 gallon pails. End price is $67.00 a pail delivered. I bought 3 pails from them recently.
   / UTF at Kioti Dealer #52
yeah i was wondering where i could find the good hyd oil and it sounds like the 424 from summit is a great price.
Well, I'm at the point where I need to change the fluid.
I heard so much about Kubota SUDT2 I called the local dealer ; $101.85 for a 5 gal pail. Full synthetic Multi-grade
I called my local Kioti dealer and they carry (and use in the shop) Wolf's Head (http://www.wolfshead.com/assets/6b_wolfshead-tractor-ht-111128.pdf) at $60/5gal. A conventional multi-grade
And Summit has the two pack of Mobil 424 for $69 + $10 s/h = $70 for 2 - 2.5 gal. (with a $5/2.5gal rebate) Net cost=$69 However it' PDS doesn't state it's grade/weight. either multi-grade or ISO. (a call to Mobil Tech results that it's an ISO46 = 20w)
I've been using TSC Traveller UTF but found it's a single grade, ie ISO46 = 20 weight. And my HST CK2510 seems to whine a lot, especially when cold and in hi range.
BUT TSC also carries Rotella HD (a UTF) which is a 10-w30 grade rated GL-4 for $58 + tax.
With winter coming (here) I think I'm going with the Wolf's Head or Rotella. SInce the Wolf's head is closer and cheaper, it's the winner.
   / UTF at Kioti Dealer #54
The traveler premium utf is a 10w20 multi weight. Not a straight 20w
   / UTF at Kioti Dealer #55
For what it's worth I just did the 50 hour service on my 2610 and used the SuperTech brand UTF from WalMart as everything else is around an hour away. It made a HUGE difference in the amount of whine from both the HST and the hydraulic pump. Whatever the dealer used when they assembled the tractor made quite a bit of noise, I couldn't believe how much quieter the SuperTech oil was. Think it was $47 for 5 gallons. I guess time will tell but so far I'd happily use it again.
Specification Description
Product Type: Hydraulic & Transmission Fluid
Brand: Traveller
Flash Point: 435 deg. F
ISO Viscosity Grade: 46
Pour Point: -44 deg. F
Manufacturer Part Number 590901
This is their Specs from the website. ISO 46 = 20W. In the verbiage it says "...Traveller Premium Universal Tractor Trans/Hydrauilic Fluid is a specially formulated, premium multigrade (SAE 10W-30) fluid .."
Two contradictory statements.
What does it say on the container?
   / UTF at Kioti Dealer #57
Brand: Traveller
That info TSC website is not correct. I actually spoke with the mfg that produces it and they directed me to their website. Here is the link http://martinlubricants.com/wp-cont...Xtreme-Premium-HD-Tractor-Hydraulic-Fluid.pdf It is a 10w30
   / UTF at Kioti Dealer #59
The Mobil 424 is supposed to be a 10-30 weight oil.
Thanks! I was a little put off by the uncertainty. I am also looking to reduce the whine. Not sure if the Wolf's Head will do that. Time will tell.
The Wolf's Head did NOT reduce the whine; it might even be worse. I'm hoping it's just noise and not bad for the tractor but maybe for the nest fluid change I'l bite the bullet and go SUDT2
CASE TV370B SKID STEER (A52706)
CASE TV370B SKID...
2008 TEXAS BRAGG 20 UTILITY TRAILER (A55745)
2008 TEXAS BRAGG...
2017 Ford F-550 (A55973)
2017 Ford F-550...
17101 (A55787)
17101 (A55787)
2011 FORD F350 SERVICE TRUCK (A52707)
2011 FORD F350...
2013 Freightliner M2 106 Elgin Broom Bear Series H Street Sweeper Truck (A55788)
2013 Freightliner...
