Using truck bed coating on Floorboards of tractor
   / Using truck bed coating on Floorboards of tractor
Awright, here they are.. such as they are. taken at night after working in the dirt for about 8 hours. I did not mask off the sections, I took everything out. and did it indoors, I do not highly recommend that. it was a lot of work to get the pieces out and back in. Good old Japanese engineering, "this piece has to come out before this one, and on and on and on." Also more springs and linkages than I would have thought.
Oh also here is a good photo of the Carter quick hitches, and my counterweight loaded with dirt tools.
James K0UA
   / Using truck bed coating on Floorboards of tractor #22
James K0UA
Certainly a lot more work taking the parts out to cover them, but you've done a professional looking job here. Congratulations!
Thanks, it was only about 100 degrees in the shade when I disassembled/reassembled them and I must have sweated a gallon on the tractor. I was actually worried about rusting it.:(
James K0UA
   / Using truck bed coating on Floorboards of tractor #24
Man, that looks good! Good job
   / Using truck bed coating on Floorboards of tractor #25
Estas Muy Bueno! :thumbsup: Very pretty. :drool:
Now that you have the process perfected, you ready to make the tour of Texas and do ours? :D:drink::cool2::welcome:
Well probably not...I got about halfway thru the disassembly, and thought about turning back, it was not much fun. I decided to do the disassembly thing because I have never been any good at masking off things for painting and I did not think it would take very long. Wrong!
But the results did look pretty good, expecially when it was clean:) and it really helps especially on that center section where my foot hits it every time when getting on, the rough surface really helps traction, and the paint was getting worn off pretty quick. I am hoping it will wear well, and will be easy to recover in place (just hit the worn spots) I have lots of material left, I used maybe 1/4 gallon
James K0UA
   / Using truck bed coating on Floorboards of tractor #27
James K0UA
It'll hold up... I 'painted' the metal floor of my motorcycle trailer 5 years ago. It looks as good today as when I covered it, and it sits outside in the weather year 'round.
   / Using truck bed coating on Floorboards of tractor #28
My brother has a bedliner machine so I had him do the rusty floorboards from my 855.
Looks good!:thumbsup:
James K0UA
   / Using truck bed coating on Floorboards of tractor #30
I think it looks real good. May try that on some of my stuff since I still have some left from a truck bed I did about a year ago.
19008 (A56859)
19008 (A56859)
2018 HINO CONVENTIONAL TYPE TRUCK (A58214)
2018 HINO...
Portable Restroom (A54865)
Portable Restroom...
2006 International 7400 T/A Altec AM55 55ft. Material Handling Bucket Truck (A55973)
2006 International...
2022 Chevrolet Tahoe SUV (A56859)
2022 Chevrolet...
2013 Ford F-250 Super Duty Service Truck, VIN: 1FT7X2BT7DEB91437, Extended Cab, 4x4, 6.7 L Power (A59076)
2013 Ford F-250...
