Using thicker oil as hydrostatic transmission wears????
   / Using thicker oil as hydrostatic transmission wears???? #1
lloydchristensen
boulder co
shibaura
What symptoms start to show as a hydrostatic transmission starts to show its age?
   / Using thicker oil as hydrostatic transmission wears???? #2
I have a swash plate design Hydro in my old Cub Cadet 129 that is about 40 years old and is still operates as the day I bought it 17 years ago. When they are wore they tend to not pull similar to how a clutch would slip and very much like when it bypasses through the relief valve.
   / Using thicker oil as hydrostatic transmission wears???? #4
Thicker oil will create more heat, which can cause all sorts of issues. Taken to extremes you could also cause high inlet restriction and mess up the pump. ISZ
Kubota BX2230D (A47384)
Kubota BX2230D...
BUYER'S PREMIUM INFO (A53084)
BUYER'S PREMIUM...
Dump Truck Body with Tarp System (A51692)
Dump Truck Body...
UNUSED LANDHONOR 4.5X2X2M GREENHOUSE (A54757)
UNUSED LANDHONOR...
UNUSED DIGGIT 20'X20' HEAVY DUTY ALL-STEEL CARPORT (A54757)
UNUSED DIGGIT...
2019 KENWORTH T680 TANDEM AXLE SLEEPER (A54313)
2019 KENWORTH T680...
