Using thicker oil as hydrostatic transmission wears????
   / Using thicker oil as hydrostatic transmission wears???? #1
lloydchristensen
boulder co
shibaura
What symptoms start to show as a hydrostatic transmission starts to show its age?
   / Using thicker oil as hydrostatic transmission wears???? #2
I have a swash plate design Hydro in my old Cub Cadet 129 that is about 40 years old and is still operates as the day I bought it 17 years ago. When they are wore they tend to not pull similar to how a clutch would slip and very much like when it bypasses through the relief valve.
   / Using thicker oil as hydrostatic transmission wears???? #4
Thicker oil will create more heat, which can cause all sorts of issues. Taken to extremes you could also cause high inlet restriction and mess up the pump. ISZ
2013 BMW 528i (A53424)
UNUSED WOLVERINE LHR-51-23W 1R RIPPER (A54757)
UNUSED WOLVERINE...
FORD 555B BACKHOE (A51406)
FORD 555B BACKHOE...
30046 (A53424)
30046 (A53424)
PALLET OF NYLON SLINGS, METAL TOOLBOX W/ CHAINS (A54757)
PALLET OF NYLON...
