Using the Woodmizer on the farm
   / Using the Woodmizer on the farm #1
123maxbars
Kubota B3200
I spent yesterday fighting off the snow and the high wind conditions but was able to capture some video of me sawing up some nice white oak on the farm.
This wood will be used for Fence Rails for the cattle.
SAWING FOR THE FARM - YouTube
   / Using the Woodmizer on the farm #2
That's a nice set up:thumbsup:
   / Using the Woodmizer on the farm #4
Got thousands of feet of white oak boards on treated posts for fencing around my farm, sawed on my Woodmizer. I paint first coat both sides with fence paint, then install, trim my posts and spray a second coat. Also run either welded wire (garden areas) or field fence wire on the inside to make them fairly animal proof.
enhance
enhance
enhance
enhance
great looking farm and fence! which woodmizer model do you have?
   / Using the Woodmizer on the farm #6
LT40 manual version bought new in 1991.
enhance
Sawing a 30' 8x12 on a 20' rated saw.....ahahaaa
enhance
Stack of 2x8 for one of my rental houses:
enhance
Making lap siding with a couple of plywood shims:
enhance
Logging out some white pine:
enhance
enhance
Pile of pine to be sawed. My shop building in the background:
enhance
nice set up!
   / Using the Woodmizer on the farm #8
You got it going on Andy:thumbsup: Both of you do! good vid.
   / Using the Woodmizer on the farm #9
I'll tell ya...if you have timber on your place, a small bandmill is about the closest to a free tool you'll ever see. I've built nearly everything on my place using wood off my place, plus 3 rental houses and numerous barns/buildings for other folks.
Most of my woodworking has construction in nature, I think Max does more furniture type stuff....something I want to get more into when I finally get my place whipped into shape. Have done a little furniture, here is a dining room table build from a nice ash log I ran into (cut from an urban lot, got for free):
enhance
enhance
One of my home made rental houses built from lumber off the mill:
enhance
2011 Peterbilt 365 Altec AC38-127S 5-Mast 127ft. 38 Ton Tri-Axle Hydraulic Telescopic Crane Truck (A56858)
2011 Peterbilt 365...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
JOHNSON OUTBOARD MOTOR (A58374)
JOHNSON OUTBOARD...
2015 FORD F-250 SUPER DUTY (A58214)
2015 FORD F-250...
2007 Hino 268 Truck, VIN # 5PVNJ8JT072S50704 (A57453)
2007 Hino 268...
Toro TRX-20 Walk Behind Trencher (A57453)
Toro TRX-20 Walk...
