Jul 4, 2009 / Using search function #1 S smokydune New member Joined Jul 6, 2008 Messages 12 The Wallenstein pop-up blocks the search function on the attachments forum. Can't make it move or go away. Anybody else? smoky
Jul 4, 2009 / Using search function #2 kennyd Advertiser Joined Jul 6, 2003 Messages 13,757 Location Westminster, MD Tractor John Deere 3720 CAB/TLB, JD455 I see it Attachments search.JPG 262.6 KB · Views: 90
Jul 5, 2009 / Using search function Thread Starter #3 OP S smokydune New member Joined Jul 6, 2008 Messages 12 Kennyd, Seeing it is not the problem. Using it is. The mentioned ad blocks the function. Enough said. smoky
Jul 5, 2009 / Using search function #4 kennyd Advertiser Joined Jul 6, 2003 Messages 13,757 Location Westminster, MD Tractor John Deere 3720 CAB/TLB, JD455 smokydune said: Kennyd, Seeing it is not the problem. Using it is. The mentioned ad blocks the function. Enough said. smoky Click to expand... OK, I just tried that and you are correct...no need to get snitty-I was just trying to help
Jul 5, 2009 / Using search function #5 carpenter383 Platinum Member Joined Dec 31, 2008 Messages 807 Location Indiana Tractor Kioti DK40SE My pop up blocker can be bypassed by holding the ctrl key while opening a page that normally would be blocked.
Jul 10, 2009 / Using search function #6 Muhammad Administrator Moderator Joined Mar 21, 1998 Messages 20,646 Location San Diego, CA Tractor None currently Yeah, I noticed this the other day... we will have to fix this. Or add it to the list of things to fix.
