Using rim guard with tire sealant
   / Using rim guard with tire sealant #1
gerard
Syracuse NY
Kubota L2500DT w/FEL
I've been putting off loading my tires because not only has it never been to the dealer yet, I put tire sealant from gemplers in and wasn't sure if I'll negate the sealant if I put in rim guard. I'm coming up on the 800 hour maintenance (need to check valve clearances) and will be bringing it in to get done. I want to load the tires with rim guard. Does anyone know what this will do with the tire sealant? I checked old posts but didn't see anything pertinent. (The sealant works great, going on 7 years without leak or a flat)
(30) Galvanized Steel Public Space Fence (A51573)
(30) Galvanized...
1999 Ford F-550 12FT. Flatbed Truck (A51692)
1999 Ford F-550...
2010 THOMPSON TRASH PUMP (A51406)
2010 THOMPSON...
2005 Ford F-750 Crew Cab Heil 5 Yd Dump Truck (A51692)
2005 Ford F-750...
2012 TRAVIS 39FT DUMP TRAILER (A52576)
2012 TRAVIS 39FT...
Ryobi Compound Miter Saw (A51573)
Ryobi Compound...
