Using hydraulics for motorcycle powered vehicle...
/ Using hydraulics for motorcycle powered vehicle... #1
partial2polo
I am designing a 3 wheel automobile using a motorcycle engine for power. The problem I have is transferring the power from the engine to the rear wheel which requires complex chain or driveshaft arrangements. I also need a reverse gear that motorcycle transmissions do not provide. My question is if a hydraulic pump and motor system could be used for the transfer of power from the motorcycle transmission to the rear wheel of the vehicle. Also, any issues with up to 150 horsepower, 125 ft lbs. torque and 10,000 rpm? Thank you in advance for your feedback.
/ Using hydraulics for motorcycle powered vehicle... #2
I probably should wait for the "real" hydraulic experts to get onboard, but the biggest problem I see is heat generated by the hydraulics. Probably take a large reservoir and big cooler to keep it cooled down. My assumptions are based on a skid steer that is hard to keep cool when working the hydraulics hard.
Thank you jbooth. That was my fear. Weight and space are significant factors and a large cooling system would not be desirable.
/ Using hydraulics for motorcycle powered vehicle... #4
Speed is going to be a determining factor. If you are moving at a good clip, you could cool your system with an aftermarket type transmission cooler. You'll still need a good sized reservoir. I think the rule of thumb is a reservoir equal to your GPM... i.e. a 10 gpm pump should have a 10 gallon reservoir.
Thank you IPlayFarmer. I could incorporate a transmission cooler with a powered fan. Not a problem. I will need to figure out GPM to determine if the appropriately sized reservoir would work. Again, thank you.
/ Using hydraulics for motorcycle powered vehicle... #7
Three wheel (trikes) motorcycles have a reverse gear. There are also after market reverse gear kits for Harleys. (not cheap!)
/ Using hydraulics for motorcycle powered vehicle... #8
Keep in mind that based on the formula at Horsepower - Wikipedia, the free encyclopedia a 150 horsepower engine at 2,000 psi will push over 125 GPM. I don't know how much a cooler can reduce the necessary reservoir volume. Hopefully a hydraulics guru will jump in with some reliable answers.
/ Using hydraulics for motorcycle powered vehicle... #9
i Think a better way, would be driving threw a manual transmission, somthing like a 5 speed ford ranger,maybe even use the rear end as well, I dont think it would be to difficult to make an adaptor to go from the output on the bike engine to the transmission, Might be as simple as cutting center out of a clutch disc amd welding it to a tube, then weld tube to sprocket on transmission output, Just a rough idea, Eric
/ Using hydraulics for motorcycle powered vehicle... #10
Also If economy is what your after, hydraulics, are the least effiecent, you will loose about 15/18 percent of your power, threw fluid drive Eric
/ Using hydraulics for motorcycle powered vehicle... #11
You need a good volume of oil in the reservoir to clear air out of the scavenged oil before you run it through the pump again. That volume of oil is essentially dead weight, plus you'll need to baffle the tank so it won't slosh from side to side in the corners - which I would think you'd want to avoid with a 3 wheeler.
I think the advice the others have given about using a gear or chain drive would be a lot less headache.
/ Using hydraulics for motorcycle powered vehicle... #12
Unless you want to move slowly with lots of low end torque and infinite speed control hydraulics are not the answer to this problem. HST by design are heat generators. The charge pump system is pure heat and lost energy a majority of the time. Your MC engine probably develops its HP at 7,000- 8,000 RPM or higher. I don't know of any HST that will run at that RPM.
Like others have stated gears and or chain are your best option.
Honda Goldwing trikes and BMW K-LT trikes all have reverse. I believe they run off of the starter motor and are intended for short distance light duty use.
Roy
Thanks a ton to all of you for your feedback and response. Looks like I have some work ahead to figure out how best to incorporate a drive shaft to a compatible rear wheel assembly (like a Moto Guzzi or Goldwing). Thanks guys.
/ Using hydraulics for motorcycle powered vehicle... #14
/ Using hydraulics for motorcycle powered vehicle... #15
Why drive the rear wheel at all? If its a three wheeler, drive the front end. Existing technology (any small front wheel drive car), light weight and efficient, better traction, better handling, more tire to hold the power, and more advantages. Just let the rear wheel tag along to hold up the trunk.
XR3 Hybrid Personal Transit Vehicle: A 125 mpg Plug-In Hybrid Three Wheeler You Build From Plans
It does sound reasonable if you can get the CV joints & diff in a small enough size to provide the swing you need while fitting inside the front track at a reasonable weight. However, both Morgan and Messerschmidt seem to have gone the OP's way (note the reverse problem solution):
Engine and transmissionThe KR200 ran on a 191 cc (11.7 cu in) Fichtel & Sachs air-cooled single cylinder two-stroke engine positioned in front of the rear wheel,[6] just behind the passenger's seat.[3] The engine had two sets of contact breaker points and, to reverse, the engine was stopped and then restarted, going backwards. This was effected by pushing the key further in the ignition switch than normal, whether intentionally or not. One result of this was that the KR200's sequential, positive-stop transmission provided the car with the same four gear ratios available in reverse as in forward movement
Messerschmitt KR200 - Wikipedia, the free encyclopedia
/ Using hydraulics for motorcycle powered vehicle... #16
I spent a year (1956) in Tokyo, and three wheel pickups were ubiquitous, delivering everything from lumber to lunchtime boxes of take-out noodles.
The front half was a 2 cylinder motorcycle, single seat, with a windshield and top, no sides. back end was a box, about 4x4, with one foot sides and a tailgate. I don't know about reverse; I (Navy brat, HS student) was more interested in my neighbor's Ariel Square Four!
I am familiar with the Morgan. I was hoping for a better reverse solution without spending $1500+ on a custom gearbox. There are options for using a high torque electric motor for reverse (ala the Honda Goldwing which uses the starter). Front wheel drive is also an option I have considered, but was trying to stay from an auto engine and all the associated emission equipment, fuel injection and other gear. I am going for a vintage look, like a Morgan, but with better driveability and performance. Ideally I will figure out an optimal method to hang a bike engine on the front and keep it simple. Thanks guys.
/ Using hydraulics for motorcycle powered vehicle... #18
use the regular transmission for forward, and if you want or need reverse, you could either use a electric starter type motor, or use a power steering pump and a small hydraulic motor that either has a one way clutch or a advancing dog similar to a starter drive to do reverse with. and attach it to the rear axle, most likely you will not be backing any real distance,
/ Using hydraulics for motorcycle powered vehicle... #19
you might look at the older Polaris 2wd four wheelers. They have a separate rugged looking chain drive forward reverse only transmission.
1999 Jaguar XK8 Convertible (A61569)
1999 Jaguar XK8...
2022 Horizon Trailer (A55973)
2022 Horizon...
Excavator Tooth Bucket (A62177)
Excavator Tooth...
2012 Chevrolet Sonic Hatchback (A61569)
2012 Chevrolet...
2017 PETRBILT 389 6X4  T/A SLEEPER TRUCK TRACTOR (A59908)
2017 PETRBILT 389...
2021 CAT 289D3 (A60462)
2021 CAT 289D3...
