Using hot water in a pressure washer
   / Using hot water in a pressure washer #1
Mosey
Conifer, Colorado
2000 New Holland TC29D with 7308 FEL, and top & tilt. 1950 John Deere B. 1940 Farmall A.
I have a Generac 2100 PSI pressure washer with an Axial Cam pump. Will hot water from the hot water tank damage it? It's supposed to get near 50 this weekend and I need to drain the tank anyway and thought I might as well get some use out of the water and wash the tractor, truck, etc.
   / Using hot water in a pressure washer #2
Not sure why, but my owner's manual says to never run hot water thru my pressure washer. Bummer, since nothing beats hot for getting ice off the underside of a car!
Pete
   / Using hot water in a pressure washer #3
I wouldn't do it. I have a different pressure washer than yours. In my manual it says to pull the trigger once a minute when not in use so as to not overheat the pump. I guess the pump seals are sensitive to heat. The newer models I think have a small bypass valve to bleed in fresh water to cool pump when not in use. Parts are expensive for these things, I found that out.
   / Using hot water in a pressure washer #4
I've got a CAT pump on mine and can run either
180 or 200 degree hot water thru it.
U need to pull trigger every minute or so because
the pressure bypass opens and recirculates the water
thru pump.
After a while it can boil or turn to steam, when water turns
to steam I believe it's 1800 time increase in volume.
I've got an outside wood fired furnace and have 180*
water plumbed into shop to use on pressure washer.
OK. I found in the manual where it says to "use only cold water, less than 100 degrees F". So, I'll just drain the water heater and use only cold water in the pressure washer. Thanks for the feedback.
   / Using hot water in a pressure washer #6
I think with hot water there is some potential it might flash to steam--and --explode! This could be the start of another urban legend, pressure washer takes out city block. Owner is --steamed! /w3tcompact/icons/shocked.gif J
2003 International 7400 T/A Heil 12 CuYd Dump Truck (A55853)
2003 International...
Mini-Excavator Quick Coupler (New/Unused) (A59225)
Mini-Excavator...
2018 SkyJack SJ1056TH 10,000LB 4x4 Rough Terrain Telehandler (A55973)
2018 SkyJack...
New Wolverine 78in Skid Steer Land Leveler (A59000)
New Wolverine 78in...
2006 GEA Westfalia Separator CA 501-00-32 Two-Phase Decanter Centrifuge (A56857)
2006 GEA Westfalia...
2009 Kubota RTV1140 (A57148)
2009 Kubota...
