Loader using FEL issue
   / using FEL issue #11
Does your relief valve activate when you try to use the bucket?
If it does, that is an indication that the bucket hoses are not passing fluid.
If you have a hyd gage in the hyd system, the gage will read high pressure when you operate the lever for bucket.
Most probable cause is a damaged QD.
Positive fix is to get new QD's, or remove the QD's and use a hyd female pipe coupling. Much cheaper.
Female Pipe Coupling (NPTF)
It is easy to test a QD by removing the QD half from the bucket side and then connect the male and female QD together and put in bucket and active the lever. If the QD passes fluid, then it is good.
Just by disconnecting and reconnecting will fix most problems,
2010 Honda CR-V SUV (A55853)
2010 Honda CR-V...
2013 Ford Fusion SE Sedan (A56859)
2013 Ford Fusion...
2012 Ford F-750 Pak-Mor 16 CuYd Rear Loader Garbage Truck (A56858)
2012 Ford F-750...
2019 Krause 8005-30 Excelerator - High Speed Vertical Tillage - 30 FT Working Width (A55315)
2019 Krause...
Doosan D355-5 Forklift (A55973)
Doosan D355-5...
2004 FREIGHTLINER CST120 TANDEM AXLE SLEEPER TRUCK (A57880)
2004 FREIGHTLINER...
