Using Dyna QPS
   / Using Dyna QPS #1
charleyfarmall
Platinum Member
Central Maine
Does anyone here have a Dyna QPS? If so, how many hours have you had it? How do you use your tractor? and... how do you like the push button shifting?
I am considering the 1660 Cab Dyna QPS for general farm and hay baling rather than a larger tractor....
Thanks
   / Using Dyna QPS #2
I have a 1652 Dyna QPS. It gets used for manure removal, grading, raking and tedding hay and anything else that needs to be done around the barn. It has 280 hrs on it with no serious issues. The push button shift has worked fine. When not under load it shifts fine w/o the clutch. Under load you need to use the clutch or it shifts a little hard.
Get the tires loaded. You'll regret not doing it during loader and field work.
   / Using Dyna QPS
I am guessing that there is no user adjustable modulation for the shifting, hence the hard shift. One of the reasons I am interested in the QPS is because of all the shifting I invariably do when mower with a sickle bar. I slow down for corners, often into first, then back to third. I'd look at the 1652 HST except that I want the higher PTO power for a larger tiller and for occasional small round baler work.
   / Using Dyna QPS #4
The dealer ca nadjust the shift harchness some - but the difference is not too noticable
2016 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A51692)
2016 Peterbilt 320...
JOHN DEERE LOT NUMBER 121 (A53084)
JOHN DEERE LOT...
BESTWAY AG VSK50 LOT NUMBER 103 (A53084)
BESTWAY AG VSK50...
RHINO X1406 LOT NUMBER 64 (A53084)
RHINO X1406 LOT...
2023 JOHN DEERE 8R340 LOT NUMBER 221 (A53084)
2023 JOHN DEERE...
2014 INTERNATIONAL MA025 26FT NON CDL BOX TRUCK (A52576)
2014 INTERNATIONAL...
