Using dirt buckets for snow removal
   / Using dirt buckets for snow removal #1
jmfox
Platinum Member
I'm wondering if anyone has experience with using a 4-in-1 bucket for snow removal. I still have my Polaris Ranger with snow blade but it would be nice to use the ASV SR80 with a heated cab. My concern is the fixed and unforgiving blade on the rubber track machine causing damage. Probably okay for dirt driveways but the cutting edge could mark blacktop surfaces.
jmf
   / Using dirt buckets for snow removal #2
Not from using a 4n1, but a normal dirt bucket will scrape the soil right off along with the snow. Just did it yesterday and it's been below freezing for the high for 2 weeks now. Shhhh, don't tell my wife. It will be a little surprise in spring....
jb
   / Using dirt buckets for snow removal #3
Plowing snow with a bucket is very difficult. The cutting edge will either ride up over the snow, or dig into the driveway. Compound the experience with limited visibility. Snow tends to load up the bucket until the machine loses traction because it can't roll off to one side. Adding a snow pusher to the loader bucket is good solution.
   / Using dirt buckets for snow removal #4
I've tried using my bucket for plowing snow. It's alright for an inch or so, but any more and it builds up and just moves off to the left or right, and the only thing you can do is push it straight ahead. A blade is much better, and that's an understatement. I've also tried it with 6 to 8 inches and it was just grief.
   / Using dirt buckets for snow removal #5
jmf
I had great results. I simply open the 4 in 1 until the front half curls all the way up and all you're left with is the back of the bucket (which looks like a small dozer blade or fixed snow plow blade). Once it's open all the way, you just push with it like a fixed snow plow blade. Then after you get piles of snow you want to move, you close the bucket and use it as a scoop.
I wouldn't suggest it for plowing long driveways or frequent commercial use. A power angling snow blade or a pusher box would be better. But for around the house on a couple driveways, etc., a 4 in 1 works good! It's like a mini fixed plow blade and a snow scooper in one package. ;)
I tried the 4-in-1 today on some wet snow and it worked pretty well. Even the blacktop drives cleaned up without any scraping that I could see. The only casualty were uneven lumps of grass. The plow tends to leve things off rather than bounce over.
jmf
   / Using dirt buckets for snow removal #7
jmf
I plow about 1/4 Acre area total at my home. 10" of snow with a B7200 took over 8 hours!. I clear two larege driveways and turn arounds. The B7200 has loaded tires, a weight box and frame weights, tire chains, so it pushes well. Weight is your friend. A 4 ft bucket just spills snow off the sides on a long run. I like wet snow as it sticks in front better. Up at our other place up north, I can do 1/4 mile of road in an hour with the weighted but no chains L39. It has same problem as B7200 same problem but bigger bucket. You can get a 4'-5' high pile in front of the bucket before you have to push it off the side. L39 lack horsepower and A HEATED CAB.
   / Using dirt buckets for snow removal #8
If you want to do minimal damage to gravel roads, get yourself a piece of 3 inch steel pipe, the same length as your bucket is wide. Cut a slot out of the pipe, so that the pipe will fit snugly over the cutting edge on the front of your 4n1 bucket. It may be necessary to rig a bracket that will hold it on, with a bolt or 2. The pipe will allow you to clear 90 % of the snow off of road surfaces, without having to rake your gravel out of the road edges in the spring. My $0.02 for $0.:D :D
Is this the voice of experience?
jmf
   / Using dirt buckets for snow removal #10
I have one of these and it's for sale now. It is fantastic going down a slight incline, level ground, but forget trying to go back up a slight incline. It will not make it without tracks. :)
The gotcha man
2006 Ford F-350 Forestry Dump Truck (A51692)
2006 Ford F-350...
2015 KUBOTA 1140CRX RTV (A51406)
2015 KUBOTA...
2009 IC Corporation PB105 School Bus (A51692)
2009 IC...
2019 KENWORTH T880 HYDROVAC (A53843)
2019 KENWORTH T880...
2025 K2215 UNUSED Portable Restroom and Shower (A53117)
2025 K2215 UNUSED...
2016 Chevrolet Colorado Pickup Truck (A51692)
2016 Chevrolet...
