Using biodiesel and various
   / Using biodiesel and various #1
Blu 82
Bronze Member
Crestview, FL
I have been told that we can't burn biodiesel in our Mahindras. Can anyone answer why or what we would have to do to burn biodiesel? Sure seems a shame since bio can be made for about $.70 vs $4.20 for offroad diesel. I think Mahindra could make a nice profit if they came out with a "kit" for dealers to install on tractors so they could burn bio (if possible).
BTW, I have 310 hrs and so far so good on my 7520. One problem is a 4-5 inch split/gash (not caused by me) in a Titan front tire. Mahindra dealer says it isn't covered under warranty. Another dealer said drive til fail then have it fixed. Another issue is the horn doesn't work--not that big a deal I guess. Other than that, no real major issues and most of the problems I have had have been operator error. My dealer went out of business and the closest one now is about 50 miles. He was a good guy.
I am looking for a 4 row planter (with dry fertilizer boxes) and a 7-10 ft disc. I have priced a new White planter and almost had a heart attack. Can someone tell me why they are about as expensive as a car?? New discs aren't cheap either! I know metal is more expensive but I didn't think these things were that complicated to be so expensive.
Sure could use some of that rain up north down here in the Panhandle of FL. Sad to see all that destruction up there.
   / Using biodiesel and various #2
You will get as many different answeres as the number of times you ask. Just yesterday I've asked that same question from a German fellow who is a mechanic for a trucking co. He said in Europe, they mix vegetable oil with diesel in warm weather only. The trouble with bio fuel, the most common, that in warm weather it is fine,but when it gets cold the fuel gells and clogs the injectors. I also listen to a radio talk show where people call in with various mechanical problems, including diesel motors, and Tom Turner, the host, said the same thing. It tends to clog the system.
The earth worshiper and tree huggers will tell you it's fine as they are more concerned about mother earth than your truck/tractor. The true test is how the fuel works after hundreds of hours. I'm not sold on biodiesel yet. I dont know what mechanical problems it could cause. Clogged injector system would require mainly labor of tearing it down and flushing the system, replacing filters and removing/replacing injectors. Go to truck stops and ask the guys who drive the big rigs and put thousand of miles on their motor. See what they think.
   / Using biodiesel and various #3
Most trucking companies around here that have their own fuel pumps (talking from experience) are running a 5% biodiesel mix. That's what my company does, and we had very few incidents of gelling and clogged filters this past winter. (a couple more than normal). I think what they're trying to do is gradually increase the amount of "bio" in the diesel to see how it's gonna be come winter time. JMHO.
Also, I work with a guy that has a Ford diesel pickup with dual tanks. He has Bio in one, and low sulpher in the other. He seems to like it, but he says he has to start the truck on the regular fuel, then switch tanks to run on the BIO. Then, before he shuts it off, he switches back to the regular, and lets it run a while. Sounds like a PITA to me
   / Using biodiesel and various #4
The no Biodiesel in Mahindra tractors, comes right from Mahindra. They gave no reason for this. If your machine is brand new and still under warranty I wouldn't think of it. If you are out of warranty then it's your chioce.
I guess the question still stands. Any dealers care to answer?
Since offroad diesel is more expensive than gas, I am sure I am not the only one looking at biodiesel. It will continue to be an issue from now on since gas/diesel prices aren't generally going to get cheaper.
As for gelling, I guess that could be considered a seasonal issue depending on what temp the issue occurs. For us here in FL, we have basically two seasons, summer and fall. Here in the panhandle we do get cold temps, even below freezing several times but generally it is well above freezing. If gelling is the only issue, that could be easily controlled by changing the fuel used based on the season.
   / Using biodiesel and various #7
There are some problems with gelling in Bio diesel especially in blends beyond B20 but the biggest problem I commonly see in the fleet industry is the quality of fuel. When you get ULSD from a marketer you can almost guarantee that the fuel you are purchasing is a quality fuel. There are exceptions but considering the volume that is distributed everyday there is not a whole lot of bad diesel out there. On the other hand BIO up until recently did not have an ASTM standard and what you got is what you got. The ASTM standard has helped but even so the the standard does not set a standard on two very important items.
One is the cloud point and there could be different cloud point for different feed stocks. One load that uses soy could cloud and gel earlier later than a load that uses animal fats.
The other is that it does not address is the blending method with diesel. Some distributors do not use inline blending and will just put diesel on top of bio in the delivery truck and depending how much splashing is occuring in the delivery truck you would not have a consistent blend.
The safest way to purchase bio is to make sure that it was produced by a BQ-9000 certified producer and that will ensure decent fuel. The biodiesel board issues this certification to producers that have passed their test. That may be hard to determine when purchasing in small quantities.
I work for a local county fleet and have been pushed to use bio in our fleet and when I did the research I did not and still do not think that it was a wise use of tax payers dollars. The city fleet uses it and this winter we had a cold snap and there were several garbage trucks parked because of gelling. No trucks=no trash pickup.
Sorry to ramble on, I just saw this thread and thought I would chime in.:)
   / Using biodiesel and various #8
I'd run a mix in the summer, but not winter.
I guess winter is OK if you have a tank heater.
   / Using biodiesel and various #9
Hey magyarbacsi:
I'm curious. Assuming all the bugs are worked out of biodiesel production, and it costs less than half what you're paying for petro-diesel, will you still not use it?
After all, wouldn't that make you a "earth worshiper and tree hugger"? We couldn't stand that now could we?
(for the humor-challenged, warning: the above post may contain sarcasm)
   / Using biodiesel and various #10
I am a fan of bio-diesel, and would have converted an old electrical water heater by now, except that a neighbor ran over my turbo-diesel VW. My use in the Tractor is not high enough to amortize the cost of the home-brew.
That aside, and as a fan of bio-diesel, I believe that what others in this thread have said is accurate, if somewhat confusing in how they presented it. My addition is about diesel engine/vehicle companies making use of bio-diesel a warranty-violator. This is common across every company that I am aware of. They apparently hope that you do not notice that in their country of origin that BD is used up to 80%, depending on the country, and time of year. My only explanation that makes sense, to me, is that here in the good old North America, there are no controls on feed stock, type and quality, and process (several QA steps). To be safe, they just write it into their warranty, then it is not an issue for them.
As a BD fan, I have never seen a documented study that clearly put blame for damage on BD. Of course, depending on the feed stock and QA, if your percentage gets over 5% in the winter, you can create a mess and have to pull the vehicle into a heated garage to get it going again.
Bio-Diesel rules!
2018 Nissan Pick Up (A47384)
2018 Nissan Pick...
FAE UML/SSL 150 VT QUICK ATTACH HYD MULCHING HEAD (A51243)
FAE UML/SSL 150 VT...
(11) 8' Treated Posts (A50515)
(11) 8' Treated...
1991 Grove RT740B 40-Ton Rough-Terrain Crane (A51691)
1991 Grove RT740B...
2019 CATERPILLAR D6N LGP HI TRACK CRAWLER DOZER (A51242)
2019 CATERPILLAR...
UNUSED FUTURE 5T HYD THUMB CLAMP (A51244)
UNUSED FUTURE 5T...
