Using B7800 with over seeder
   / Using B7800 with over seeder #1
bobditt
Kunitz B7800
I have a Kubota B7800 and want to acquire a 48” over seeder and am looking at the OS1548. Will the B7800 be ok with that over seeder or are there other recommendations by anyone. I am new to this, own the tractor and need to over seed around 10 acres. Thanks
   / Using B7800 with over seeder #2
In the pictures, I see them running it with a L3901, so that machine has around 30 HP to the PTO and your B7800 has 22 HP to the PTO. Both can lift about the same.
I would say it should work.
Thanks for your input.
   / Using B7800 with over seeder #4
I run an Toro/Olathe Aerothatch 83 with a 93 model seeder on my B2620 twice, its a 48" slit seeder that weighs close to 1000lbs empty and can hold around 100lbs of seed. The B2620 is maxed out and can't fully lift it with a full seed box.
Power wise it can run it but if our clay soil is damp then I really have to slow down a lot.
According to tractor data your tractor has about 3hp more at the pto and the 3pt lifts just under 250lbs more at 24".
I would say that if you can even lift the 1548 with a full seed box you probably won't me happy going over 10ac with it and would feel like you're pushing the machine too much.
With the seeders there's a lot of weight pretty far out, this year I'll be using my Toro/Olathe behind a L3240 which handles it much better.
I'm not sure if they are still making them but Befco and Jacobson use to have some smaller/lighter 3pt seeders, and of course I've been very happy with my Toro Aerothatch 83/93 combo.
   / Using B7800 with over seeder #5
Also depending on soil conditions you can look at an Aera-vator, not a slit seeder but uses peg style tines to fracture the soil, the soil conditions have a little bit smaller window to work in compared to the slit seeders though.
2008 Ford F-750 Crew Cab Pro Patch TCM-425-135 Asphalt Patcher Truck (A48081)
2008 Ford F-750...
1995 Pro Sports 22ft Center Console Fishing Boat with 25ft T/A Boat Trailer (A48082)
1995 Pro Sports...
2022 Case IH 8250 4WD Combine (A50657)
2022 Case IH 8250...
Gravely ZT2350 Zero Turn Mower (A50860)
Gravely ZT2350...
2005 Toyota Corolla Sedan (A48082)
2005 Toyota...
WEATHERFORD MP-10 TRIPLEX MUD PUMP POWERED BY A CATERPILLAR 3412 ENGINE (A50854)
WEATHERFORD MP-10...
