Using a Tarp To Replace Cover on ShelterLogic Shed for horses
   / Using a Tarp To Replace Cover on ShelterLogic Shed for horses #11
I have thought of that. It is quite a bit more expensive, and I have heard of horror stories if you don't have it well secured. But if secured well, I think it would last a long time and be a good option. I haven't priced one out compared to building a wood shelter.
I thought a metal cover might be a good idea, too.
I looked into that when I last replaced my cover. I came away with two thoughts;
1) getting an aluminum corrugated material would probably work best for waterproofing reasons at the peak of the shelter (best overlap on the horizontal), and
2) getting a good end cap to protect the animals from getting cut was essential.
Lacking a tubing bender, I didn't come up with a method to generate or buy end caps, and gave it up. Ideas or suggestions would be welcome.
Others are definitely handier than I when it comes to fabricating end caps, and may have some great ideas. There also isn't a great selection of metal roofing locally, but that wasn't what killed it for me.
YMMV...
All the best,
Peter
   / Using a Tarp To Replace Cover on ShelterLogic Shed for horses #12
Things I learned with fabric buildings: If one encloses the stored item and even if open-ended aerodynamic lift is strong with much-reduced flow under the cover. My most durable were 'carports' as sold (NLA) and have withstood winds in the worst spot in the nabe for wind. The fabric only goes to within 3' of the ground. Better ones (painted square tube, w/ends/doors) have been blown about the neighborhood.
Were I to recover a frame I'd give a lot of thought to say a solver HFT tarp that could be secured with space for air circulation and to trim/spray around. Backhoe & trickler, bicycle, stay dry and in iffy weather I hang my wash in mine. I credit not trying to stand up to wind with longevity of the setup. OK here's a pic of the longest standing fabric shelter anywhere near here.
   / Using a Tarp To Replace Cover on ShelterLogic Shed for horses #13
Were I to recover a frame I'd give a lot of thought to say a silver HFT tarp that could be secured with space for air circulation and to trim/spray around. ... here's a pic of the longest standing fabric shelter anywhere near here.
I haven't had as good experience with HF tarps. Here's my last one after it was up for 8 months. Claimed 'premium HD' silver tarps via Ebay lasted longer, as I recall, typically two winters then failed before the third winter. There's likely better quality out there somewhere but I don't know how to find those.
20180218_173410rtarp-jpg.540619
   / Using a Tarp To Replace Cover on ShelterLogic Shed for horses #14
The eyes surely don't have it. :sneaky: IMO too few eyelets too far apart is the bane of econo-tarps tied down in windy conditions. The HFTs I've had lasted 3-5 yrs when not depending on OEM mounting holes to hold up & to hold 'em down. There's a way to get around that.
In my pic above (at full size) you can see that there are 'rod pockets' sewn into the edges of the cover. In the ends the pockets contain extra-long ratchet straps anchored at the frame's corners to screw anchors and on the sides there are 'notches' to attach to what could be 3/4 metal conduit or PVC, then lashed or weighted. Most any sewing machine would do if one uses a synthetic, coat-button type or other heavy thread and bobbin. Having a helper to manage a large tarp for this is indicated.
btw, longer spans and fewer anchor points will make cover survival difficult. IMO 6' spacing of tubes/ribs is a high practical limit. I prefer 5' at most. Anyway using a cheap tarp is one thing, asking too much of it is another, and I have done so. :rolleyes: YMMV as always.
   / Using a Tarp To Replace Cover on ShelterLogic Shed for horses #15
I have had good luck with Northern Tool's premium grey tarps. I don't know that the ones today are the same quality, but I have two from a decade ago that I am still using, after a more than a few years in the sun and rain.
They have (or had) rope sewn in along the edge and more frequent grommets.
All the best,
Peter
   / Using a Tarp To Replace Cover on ShelterLogic Shed for horses #16
I had a framework up for over 20 years. Went through 3 or 4 tarps. The frame work was fairly flat pitch, maybe 2/12 pitch. I took 3/4" pvc pipe ant attached it to the top plate pipes of the frame. (Think of top plate in house wall.) Ran the pvc under the ridge pipe and zip tied it to the ridge pipe. Puffed the pvc up and it lifted the sag out of the tarp. These pvc pipes were about 3 to 4ft apart. The frame's rafter pipes were 10ft apart. This kept the water from collecting at the lower edge. Also it supported the snow load for the most part. I did clear snow as soon as I could. This was in the snow belt of northern Michigan. Jon
   / Using a Tarp To Replace Cover on ShelterLogic Shed for horses #17
Cheap is cheap and what you get don't last. I have 2 Clearspan Truss arch buildings, one I keep hay in the other equipment in and both are 15+ years old with zero issues. You get what you pay for with everything in life, fabric structures included.
   / Using a Tarp To Replace Cover on ShelterLogic Shed for horses #18
We were trying out some shelterlogic canvas garages as shelters for horses because they are relatively cheap compared to a wooden one (especially these days!) and quick to put up. The first one we tried it got blown over in the wind and destroyed. Luckily no horses were injured. They were inside the barn at the time, but it did take out one fence post. The second one we put up I anchored with t-post at each leg and secured them to the shed with metal hose clamps. Then the horses and the wind destroyed the canvas cover.
Instead of just scrapping this thing or buying another cover that I imagine would be $200 or so, I decided to just use a tarp. Seems to be working OK, and if it gets ripped or destroyed its only going to be $50 to replace. You can see how what I did in the video below.
I am a little concerned about snow load, but I have some ideas to help mitigate that.
Curious as to how it’s holding up and if you made any other modifications? Great video thanks for sharing!
KENMORE 80 SERIES WASHING MACHINE (A54757)
KENMORE 80 SERIES...
2016 CATERPILLAR 336FL EXCAVATOR (A52705)
2016 CATERPILLAR...
FORREST RIVER CHEROKEE CAMPER (A52472)
FORREST RIVER...
2008 Ford F-450 Knapheide Service Truck (A55788)
2008 Ford F-450...
JOHN DEERE 6155M (A53084)
JOHN DEERE 6155M...
2008 New Holland B110 MFWD Loader Backhoe (A57024)
2008 New Holland...
