using a rake on my BX2230
   / using a rake on my BX2230 #1
dexter
I am new at this. I have a Bx2230 and looking for a landscape rake. Will any rake work on the BX series.. Thanks for any help..
   / using a rake on my BX2230 #2
dexter,
The short answer is yes. I have a BX1500 with a full size rake and rear blade. They both work fine. If you are not looking to spend a lot of money, King Kutter makes a decent rake for the money. I have one of their box blades and have been pleased so far.
   / using a rake on my BX2230 #3
Having owned a B2410 and a WOODS landscape rake and now owning a BX23, I would go with a rake designed for the BX series. Woods makes a estate landscape rake for the BX and king kutter makes a XB rake.
You will get a better lift on the BX designed rake and it will be easier to control. The WOODS full size 5 foot rake sometimes felt too large and cumbersome on the B2410. Although you may be able to adapt it to a BX it would likely feel akward and not be able to adjust the angle of toplink tilt as well.
Thanks for all the info..
Dex
   / using a rake on my BX2230 #5
I'll second Nik's recommendation. I had a 6' full sized rake on my BX 2200, and although the tractor actually got work done well with it, the overall size of the unit was cumbersome. I traded it on a Woods Estate series and am much more satisfied. When I was looking, I found prices between the KK and the Woods to be very close (in my area), but the Woods was a much nicer unit.
Will
   / using a rake on my BX2230 #6
dexter,
You are getting a lot of good advice. One of the reasons I went with full sized implements (I built my rake) was for possible resale down the road. I would limagine that full sized implements would be easier to sell (if you want to buy others:) ). Where I am, Woods stuff will run a few hundred dollars more. It is nice though. I just couldn't get approval from the household CFO to buy it.:D
   / using a rake on my BX2230 #7
I have used a 6' york rake a few times with my BX22. I was able to use some chain to link the lift arm to the 3PT arms and use the implement lift to lift and lower the rake. Made life a lot easier.
paul
Takeuchi TL150 (A50120)
Takeuchi TL150...
Fuel Tanks and Ladder (A47384)
Fuel Tanks and...
1998 John Deere 544H Articulated Wheel Loader (A50322)
1998 John Deere...
INSPECTION (A51572)
INSPECTION (A51572)
Stanley MB3570 Skidloader Breaker (A50774)
Stanley MB3570...
2016 Freightliner Cascadia Tandem Axle Road Tractor (A47384)
2016 Freightliner...
