Using a pull behind blower
   / Using a pull behind blower #1
shooterdon
Elite Member
Near Johannesburg MI but in the middle of nowhere
2019 LS XR4140 HST Cab; 2020 Kawasaki Mule SX; 2021 Bad Boy 54" ZT Elite
If there is a 12” snowfall, is there a problem after the first pass when only 50% of the blower width is being used on the second pass. One side of the tractor is close to the ground while the other side is riding on the snow...may be 4” or so higher.
   / Using a pull behind blower #2
The 3 point that the blower is attached to will compensate for the small height difference while driving over snow. You will be fine.
   / Using a pull behind blower #3
I have no problems like you are concerned with.
Blower will be flat on the ground even if the tractor is slightly tilted.
90" inverted blower
Dave M7040
   / Using a pull behind blower #5
Thank you for the feedback gentlemen.
great question, even if the snow is fairly deep it compacts and spreads under the wheel do the difference is nt as great as you might think. It is analogous to using a rear blade on snow and there the float in the hitch evens things out.
2013 FREIGHTLINER CORONADO 122 SD (A45333)
2013 FREIGHTLINER...
13'x20' Single Garage Metal Shed (A44502)
13'x20' Single...
2013 Ford F-350 XL Super Duty (A44501)
2013 Ford F-350 XL...
JLG1930ES (A45046)
JLG1930ES (A45046)
1996 International 4700 Box Truck, VIN # 1HTSCABP2TH265415 (A44391)
1996 International...
SWEETWATER METAL PRODUCTS LINE TAMER TRAILER (A45333)
SWEETWATER METAL...
