Snow Equipment Owning/Operating Using a pickup snow blade for my Mahindra
   / Using a pickup snow blade for my Mahindra #21
Very cool!!!! Did you design that??
The "spring" thingy was already there when I bought the machine, but I did modify it with the triangle plate and added a chain, The spring shock was welded to the frame also and I ground it off and made the stopper plate, I didn't like the angle of the frame before. Heres a pic of what it looked like before....
   / Using a pickup snow blade for my Mahindra #22
You have gotten good advise so far.
Go with the chains. Thats a lighter duty plow and not made to take the abuse of a rigid set-up.
And ditto keeping the a-frame level. That keeps it level when you angle. I like the idea of a skid shoe or two on the SSQA plate. Makes it easier with the loader to return the lift to the same "level" spot everytime.
The part that is wore down is refered to as a cutting edge. About $100. I get edges for my plow from angelos-supply
   / Using a pickup snow blade for my Mahindra #23
   / Using a pickup snow blade for my Mahindra #25
Nice plow.
   / Using a pickup snow blade for my Mahindra #26
file:///C:/Users/bigdawg/Pictures/TRACTOR/IMAG1803.jpg
This is how I mounted my plow to the pallet fork frame. It can pivot up and gravity has it resting down against the frame.
2024 JOHN DEERE 35P LOT NUMBER 107 (A53084)
2024 JOHN DEERE...
2018 John Deere 30G Mini Excavator (A52377)
2018 John Deere...
UNUSED Grey Waterproof PE Tarpaulin w/Grommets (A53117)
UNUSED Grey...
2018 Ford F-450 Ext. Cab 4x4 Mason Dump Truck (A53422)
2018 Ford F-450...
Hustler 60in Zero Turn Mower (A55851)
Hustler 60in Zero...
2014 Ford Taurus AWD Sedan (A55853)
2014 Ford Taurus...
