Using a PHD on a CCYanmar Sc2450 ?
   / Using a PHD on a CCYanmar Sc2450 ? #1
Scrambler82
SoCal
Mahindra Max 28XL, HST, TLB
Using a Posthole Digger on a CCYanmar Sc2450 ?
Has anyone used one of the 7200 JR Posthole diggers on there SCUT ?
I own a CCYanmar-Sc2450 and thinking about getting one... but also thinking (smoke) if the tractor will lift the Attachment high enough for travel and removal from the hole.
I watched the video from EA.com about the fitment but they do not show a SCUT using it just a larger framed tractor.
Anyone have an opinion on this ?
Thanks for reading and for any opinions.
   / Using a PHD on a CCYanmar Sc2450 ? #2
I haven't used that one, but I have a woods phd 35 on my Sc2400 with a 42" L x 9" diameter auger, I think it is.
I want to say that there's about 6" or so from the point on the auger to the ground with the 3pt at it's highest settings. When I have it on and I'm driving around with it, I tend to keep an eye on it though as the point will drag the ground depending on the level of the ground. I've used it a couple of times and the Sc2400 seems to handle it just fine.
It looks like the 7200 JR will fit on the JD2305 so I don't see why you would have any problems on the Sc2450.
http://www.tractorbynet.com/forums/attachments/119427-leinbach-7200jr-phd-power-take.html
The pics look like it will work, I will check out the size difference.
Yes I looked at that vid but I didn’t know how the two SCUTs matched up.
Thanks
   / Using a PHD on a CCYanmar Sc2450 ? #5
i have a yanmar 2000 and have used my neighbors PHD that is from tractor supply company. I can clear the hole and road when lifted up to move around as well as lower it to as deep as the auger will go.
2008 RIB 24 Cat Boat (A50324)
2008 RIB 24 Cat...
2014 Jeep Cherokee SUV (A50324)
2014 Jeep Cherokee...
2017 Chevrolet Express 2500 Cargo Van (A50323)
2017 Chevrolet...
Case Ih 2388 Combine (A50514)
Case Ih 2388...
LOAD OUT AND SHIPPING (A51572)
LOAD OUT AND...
1262 (A50490)
1262 (A50490)
