Using a Landscape Rake
/ Using a Landscape Rake #1
Lou_B
Connecticut
Massey 2860M
I just started using a landscape rake to remove rocks, level, and prepare an area for seeding with a grass mix. Up till now, I never had the opportunity to work on a big area.
Our sportsman's club decided to rebuild our rifle range. The big equipment is finishing up and we now have an area about 300 yards long and 200 ft wide full of Connecticut soil. Connecticut soil seems to be mostly rock.
I'm finding that it is difficult to get a decent rock-free area ready for planting. The landscape rake does a good job in leveling the area but just when I think an area is done, more rocks are pulled up. After 7 hours of work, the job is 1/3 done.
Does anyone have any tips for using a landscape rake? I'm using a fairly agressive angle (top link adjusted out) to start out and then shift to a mild angle when most of the bigger rocks are pulled to the surface. It takes 4 or 5 passes over the same area at different angles to get things relatively rock-free.
A view work in progress is attached. Anyone need some rocks? There are plenty!
Lou Braun
/ Using a Landscape Rake #2
I also am in CT and I have found that you just get the majority out of the way and go forward from there. I just came in from pulling my share of boulders that have come to the surface after the winter "heave". I do this every year and it is a never ending project. The only other thing to do is have someone prepare it with a Harley rake and you will then have enough rocks to start your own rock crushing business.
/ Using a Landscape Rake #3
That looks great Lou - I'm close to starting that same process - I've been clearing some land for a while and I hope to start raking it out next weekend. Thanks for the picture,
/ Using a Landscape Rake #4
Go slow, take your time, those rocks arent going anywhere(you'd wish).
Do you have anymore pics of your Challenger? Do you like the machine?
/ Using a Landscape Rake #5
That looks great!
For the rocks? Well why not do an "Open Field Day", give everyone a five gallon bucket and hand out prizes for most collected?
I did this with my kids, paid them a dollar a bucket! And two years later I am still getting rocks, it never really ends.
Good luck,
-Mike Z. /forums/images/graemlins/grin.gif
As you suggested, the rake works better at slower speeds. Using draft control set to slower 3-point lift response really pulls rocks out of the ground.
After raking a bit less than 3 acres, we took a time out to pick up rocks and toss them in the loader bucket. I lost track of how many bucket loads we removed!
The Challenger worked fine and the 7' rake didn't slow it down a bit. These tractors (and the practically identical Massey's) are tough machines.
Lou Braun
The main reason we decided to grade the area and remove all the rocks was to prevent ricochet and to plant tough grass for erosion control. The area needs to be smooth and rock-free to allow us to mow it later.
Range design is much more complicated than I first expected. We needed to have ricochet control (no bare rock showing) and backstops that will collect all the projectiles that are fired (lead control).
The biggest part of this job is removal of a large section of rock that was between the 25 and 100 yard line. This section required blasting. A photo of one rock pile is attached. No, a compact tractor can't even begin to budge this stuff - that job was saved for a D-8 Cat.
Lou Braun
/ Using a Landscape Rake #9
I've been watching this thread to see if it can help me also. I too am trying to clear a huge amount of small, medium and large rocks from our land with a landscape rake and not having great results. I made a few passes with a box blade with teeth down to dig up the soil and larger rocks first and took out rocks by hand that I thought would be too big for the rake. I was then left with literally thousands of rocks that I was hoping the rake would pick up. After using the rake for a few hours I am not much better off than when I started. My problem is that the rake seems to pull as much dirt as rocks with it acting more like a rear blade than a rake. I have rows of rocks now but they are mixed in with a bunch of the soil. The rake also misses many of the rocks, usually just going over them. I took every third tine off to try to let more dirt pass through but no luck. I changed the angle of attack and tried tilting the blade and using it straight but that did not help either. I could ultimately probably get most of the rocks out with the rake but I would also end up taking out a large amount of our topsoil at the same time. Am I doing something wrong? Help me please!!!
Matt
/ Using a Landscape Rake #10
Harley Rake Enough Said!!!! You would be done already. /forums/images/graemlins/cool.gif
/ Using a Landscape Rake #11
Yep on the Harley Rake,
York rakes are finders of rocks, not collectors. I use my kids for the collection. I just LOVE that sound when I am using my rake and think I am almost done, when I hit the 2 pound quartz rock on the final pass......
/ Using a Landscape Rake #12
I agree with the Harley Rake. I found I could only pick up about 50% with the York Rake. The best I could do is set the top link for an agressive setting. After a few passes the rake loosens up the soil and takes more soil than rocks. After a weeks or so after the dirt tightens up a little, I could go back out a make a few more passes. I've ended up hand-picking most of mine, about 6yds for 2 ac. of lawn. I tried to rent a Harley Rake, but my tractor doesn't have rear hydraulics.
/ Using a Landscape Rake #13
Wisconsin is the rock capitol.... I know it for a fact. Pulled out a 500 plus pounder today with the loader. I have rented a harley rake several times with good results. The only problem is one part is on a hill side which is an invitation to a 3" rain fall in 20 minutes. The rocks grow like clock work every year. I wonder what it would be like to live in sand country?
/ Using a Landscape Rake #14
Now you have done it..... you have started the Great Rock Debate. 500 pounds... why that is just a pebble compared to my rocks. My rocks are so big that there isn't a portable scale that will even weigh them. In short, bring it on....show me your rocks, because I know that my rocks are bigger than your rocks!! /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
/ Using a Landscape Rake #15
Oh man...let's rock /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
It sounds like the dust that blows off the rocks at my place in PA must've landed in Wisconsin. Some probably blew over to CT, too /forums/images/graemlins/tongue.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
I started a new thread for this... Let's Rock
Let's see what you got...
-JC
/ Using a Landscape Rake #17
Rocks.....what are rocks? My rocks are a few miles straight down. I have nothing but sand. Fortunately, I have a perched water table so usually have plenty of moisture for growing things. Boy do things grow. Grass can grow a foot in a week. By the time I got my new tractor this year and finished overhauling my Bush Hog the grass and light brush was up to the hood of a Kubota L3130. One pass takes it down easily though.
Vernon
2019 RAM 5500 4X4 S/A ROLLBACK TRUCK (A59914)
2019 RAM 5500 4X4...
53ft Dry Van Trailer (A65563)
53ft Dry Van...
2018 CATERPILLAR CS44B SMOOTH DRUM ROLLER (A65053)
2018 CATERPILLAR...
2022 SWARTZ 100" X 40' GOOSENECK TRAILER (A64276)
2022 SWARTZ 100" X...
New 5400LB, Rachet Binders and G70 Chains (A62679)
New 5400LB, Rachet...
EZ Trail 3400 Gravity Wagon (A66285)
EZ Trail 3400...
