Grading Using a dual blade grader on frozen gravel
   / Using a dual blade grader on frozen gravel
The grader arrived on Tuesday. Now I have to wait until spring to try it out. They are hard to see in the picture, but the wear skids have two shims (full length) they can be removed to lower the blade.
oops - posted the wrong picture.
   / Using a dual blade grader on frozen gravel #14
Looks good. No question you will enjoy using that come warmer weather.
gg
   / Using a dual blade grader on frozen gravel #15
Those lower lift arm brackets look a little lacking in design ? Is the top link mount braced , hard to see in pics . Frozen ground will sort that out . Otherwise , nice looking unit .
2013 Cummins ISL G 300 8.9L 6-cylinder Turbo Diesel Engine (A55851)
2013 Cummins ISL G...
2023 G Bar K Goose Neck Flat Bed (A55218)
2023 G Bar K Goose...
2019 John Deere 210G Hydraulic Excavator (A55851)
2019 John Deere...
1997 Caterpillar D3C Series III LGP Crawler Tractor Dozer (A55851)
1997 Caterpillar...
2016 Ford F-150 Ext. Cab Pickup Truck (A55852)
2016 Ford F-150...
UNUSED WOLVERINE SG-13-08D HYD 8" STUMP GRINDER (A57193)
UNUSED WOLVERINE...
