Using a Cat. 0 post hole diger with a 4025
   / Using a Cat. 0 post hole diger with a 4025 #1
raysmithtx
Fort worth, texas
Mahindra 4025 and a Bobcat E35 excavator
I know this may be confusing but I have tried to make it as clear as I can.
When I bought my used 4025 tractor a few years ago they included a post hole digger. Well yesterday I tried to connect it to my tractor for the first time. The PHD needs a Cat 0 pin. The existing top link pin is actually a stepped pin going from Cat 1 to cat 0 but the Cat 0 part is not long enough. The top link pin will not go through far enough for the latch pin hole to be usable because the Cat 1 shoulder part of the pin hits the PHD connection and stops it short. I have looked for Cat 1 to Cat 0 stepped pins and cannot find them.
Do I need to buy a Cat 1 to Cat 0 bushing and then use a long Cat 0 pin? Or do they make long stepped pins that go from Cat 1 to Cat 0 and I'm just not good enough at Googling to find it?
I'm hoping someone on the forum had this problem and found a solution and won't mind sharing it with me.
Thanks.
   / Using a Cat. 0 post hole diger with a 4025 #2
I don't know the particulars, or about a stepped pin, but a Cat 1 to Cat 0 bushing and a long Cat 0 pin should work.
   / Using a Cat. 0 post hole diger with a 4025 #3
Thanks.
I had to buy a new top link for my 4025. I wound up getting a category 2 top link for the tractor, and got a category 1 bushing for the implement.
I believe your line of thinking will work.
John Deere 4520 Tractor (A50514)
John Deere 4520...
2018 Ford Explorer AWD SUV (A50324)
2018 Ford Explorer...
2011 KOMATSU PC160LC-8 (A52472)
2011 KOMATSU...
1992 Ford Explorer (A50515)
1992 Ford Explorer...
Case 580 Backhoe Loader (A50514)
Case 580 Backhoe...
