Using a Cat. 0 post hole diger with a 4025
   / Using a Cat. 0 post hole diger with a 4025 #1
raysmithtx
Fort worth, texas
Mahindra 4025 and a Bobcat E35 excavator
I know this may be confusing but I have tried to make it as clear as I can.
When I bought my used 4025 tractor a few years ago they included a post hole digger. Well yesterday I tried to connect it to my tractor for the first time. The PHD needs a Cat 0 pin. The existing top link pin is actually a stepped pin going from Cat 1 to cat 0 but the Cat 0 part is not long enough. The top link pin will not go through far enough for the latch pin hole to be usable because the Cat 1 shoulder part of the pin hits the PHD connection and stops it short. I have looked for Cat 1 to Cat 0 stepped pins and cannot find them.
Do I need to buy a Cat 1 to Cat 0 bushing and then use a long Cat 0 pin? Or do they make long stepped pins that go from Cat 1 to Cat 0 and I'm just not good enough at Googling to find it?
I'm hoping someone on the forum had this problem and found a solution and won't mind sharing it with me.
Thanks.
   / Using a Cat. 0 post hole diger with a 4025 #2
I don't know the particulars, or about a stepped pin, but a Cat 1 to Cat 0 bushing and a long Cat 0 pin should work.
   / Using a Cat. 0 post hole diger with a 4025 #3
Thanks.
I had to buy a new top link for my 4025. I wound up getting a category 2 top link for the tractor, and got a category 1 bushing for the implement.
I believe your line of thinking will work.
UNUSED JCT SKID STEER QUICK ATTACH 84" DOZER BLADE (A51244)
UNUSED JCT SKID...
New Idea Tandem Manure Spreader (A50774)
New Idea Tandem...
2016 SKYJACK SJ6832RT SCISSOR LIFT (A51242)
2016 SKYJACK...
2008 Nautica International RIB 24ft Cat Boat with T/A Boat Trailer (A50324)
2008 Nautica...
2008 Freightliner B2 School Bus (A51692)
2008 Freightliner...
2021 Doosan DX350LC-5 Hydraulic Excavator (A50322)
2021 Doosan...
