Using 4' boxblade on BX24 in high gear bad?
   / Using 4' boxblade on BX24 in high gear bad? #1
mswlogo
NH, USA
Kubota B2320 DT (Gear)
I have a long dirt road I maintain with the BX24 and 4' box blade. It's been working fantastic.
Sometimes I put it in high gear to speed the job up. It doesn't seem to phase the tractor and I only do it if the box blade is lightly filled or I'm polishing it off.
But when I do this I do smell a whiff of "clutch" type smell now and then.
Tractor still only has 20 hr's on it didn't know it was working harder and some something new is still burning off (like a decal on exhaust type thing). Smells like brakes/clutch. But I didn't think I could smell something like this on a hydro.
Am I cooking something doing this?
Maybe at high speed I'm smelling the blade burning :)
P.S. The light duty woods 4' box blade with no weights has worked perfectly fine. The road it packed like concrete and breaks up fine when I ask it too.
   / Using 4' boxblade on BX24 in high gear bad? #2
Try low range is smell gone? Most of the time when using a back blade or such I use low range with no problems or smell's.Whats the rush?
No smell in low. That was implied.
Time is money.
   / Using 4' boxblade on BX24 in high gear bad? #4
You are most likely smelling the air from the hydraulic system vent just behind the seat. The vent looks like a little red button. Probably has nothing to do with the HST range you're using, other than the hyd fluid may be getting warmer when you use high range. As the oil gets hotter it emits more odor.
   / Using 4' boxblade on BX24 in high gear bad? #5
agree, I get this smell when "working the tiller hard" it is also a sign to check level of the fulid. ....
   / Using 4' boxblade on BX24 in high gear bad? #6
mswlogo,
I too get that smell when I use my landscape rake on our dirt lane in high. I was always wondering the same thing. Thanks for taking the time to ask. I did not know that red button looking thing was a vent.
Makes sense.
Deano
Thanks guys, I'll double check levels.
So if it "feels ok" to do some work in high gear I should be ok?
   / Using 4' boxblade on BX24 in high gear bad? #8
Yes, shouldn't be a problem
2023 CATERPILLAR 299D3 SKID STEER (A51242)
2023 CATERPILLAR...
2015 BOBCAT E35 EXCAVATOR (A51242)
2015 BOBCAT E35...
1275 (A50490)
1275 (A50490)
UNUSED 2025 INDUSTRIAS AMERICA 7014 DUMP TRL (A51243)
UNUSED 2025...
2016 FORD EXPLORER (A51406)
2016 FORD EXPLORER...
County Line 5' Poly Feed Trough (A50515)
County Line 5'...
