User and operating manual Iseki TL 2500
   / User and operating manual Iseki TL 2500 #1
pasajeroBg
Hello people
I'm from Bulgaria and I'm new here.
Last week I bought tractor Iseki TL 2500, we have not big traditions in our country for machines who are not made is USSR and I can't find user manual and I don't know how operate accurately with the machine.
I can't turn off lock and 4WD system and anything.
Please if somebody can help with some operating and user manual, or download link, I will be very thankful.
Regards: Peter
   / User and operating manual Iseki TL 2500 #2
Hi peter,
I am writing you from Slovakia. Same story here.
I contacted Iseki Europe for a manual for my TL1900 but no succes. They have them but it are "heritage" collection things they dont support anymore.
Best bet to buy a copy online and import it from the US but i know how complicated such a simple thing can turn out with our customs.
If you specify your questions a bit more i am willing to get you through by text and pictures but you might better post this in the Iseki sub forum.
Sitting on the tractor you find 3 levers above floor level. 2 left, and 1 right.
Left1: H pattern: PTO speed selector, middle is neutral
Left2: up-down position: up= 2WD, down= 4WD
Right: this is not a handle but a rod-pedal : the diff-lock. You press it by foot while driving. (at moderate speed) to engage.
On your left hand side on the wheel arch you find 2 levers:
left one: 2 positions: high and low gearing. (low= creep)
right one: transfer gearbox:
-2nd speed: completely down
-3rd speed: 1 position up from 2nd
-Neutral: 1 position up from 3rd.
-1st speed: completely up.
Playing around with these settings should get you on the move.
Normal operation should be 2nd speed-High and then the gears with the gearstick.
If you are in Low and 1st or even 2nd speed and a low gear you will at idle barely see the tractor move. These are the creep speeds.
Hope it helps.
Hi peter,
Hope it helps.
Thank you for help ...
Actually I want to change the oil in engine and hydraulic system.
Do you know how litres is the engine oil capacity and gearbox, do you know which type of oil I must use for hydraulic system and gearbox and is they with different type of oils or gearbox and hydraulic system are with one type?
How can I check oil levels?
Thank you for answers again.
Regards: Peter
   / User and operating manual Iseki TL 2500 #4
Peter,
I have no idea on the cappacity in the TL2500.
In any case:
- 15W40 diesel engine oil should do it for the engine. (might want to go to a 10 grade in winter)
- the gearbox and hydraulics are 1 reservoir with a dipstick next to the gearstick and a drainplug on the bottom side of the transmission tunnel. On top of the tunnel you have a black +- 5cm diameter rubber plug: the fill hole .
Universal hydraulic-transmission oil can be used there. (i dont remember the exact type number but it was a common oil for tractors so your store should know) Expect somewhere between 15 and 30 liters of it to fill up. (The TL2500 has the TL2300-2500-2700 frame so i have nu idea how much it takes compared to the TL1700-1900-2100 frame)
1 thing on the hydraulic oil: if you dont know what is in, you better drain it completely. That means also from your implement cylinders and replace all with 1 type.
Mixing oils can do funny (read: expensive) things and you sometimes wonder how that much crap can get into it.
For your front axle you can put the usual axle oil. (EP90 if i am correct) or some just put there also the hydr-universal oil.
Thank you very much Tatra, this information is very valued for me.
2016 Ford F550 4x4 Bucket Truck with Altec AT41 - 46FT Rotating Bucket and Jib Winch (A53473)
2016 Ford F550 4x4...
2014 CATERPILLAR TL642C TELESCOPIC FORKLIFT (A51246)
2014 CATERPILLAR...
2012 PROCO 130BBL VACUUM TRAILER (A53843)
2012 PROCO 130BBL...
2015 Toro Workman MD Utility Cart (A53421)
2015 Toro Workman...
2012 LEEBOY 8515B APHALT PAVER (A51406)
2012 LEEBOY 8515B...
2001 INTERNATIONAL 4700 4X2 SERVICE TRUCK (A52706)
2001 INTERNATIONAL...
