User and operating manual Iseki TL 2500
   / User and operating manual Iseki TL 2500 #1
pasajeroBg
Hello people
I'm from Bulgaria and I'm new here.
Last week I bought tractor Iseki TL 2500, we have not big traditions in our country for machines who are not made is USSR and I can't find user manual and I don't know how operate accurately with the machine.
I can't turn off lock and 4WD system and anything.
Please if somebody can help with some operating and user manual, or download link, I will be very thankful.
Regards: Peter
   / User and operating manual Iseki TL 2500 #2
Hi peter,
I am writing you from Slovakia. Same story here.
I contacted Iseki Europe for a manual for my TL1900 but no succes. They have them but it are "heritage" collection things they dont support anymore.
Best bet to buy a copy online and import it from the US but i know how complicated such a simple thing can turn out with our customs.
If you specify your questions a bit more i am willing to get you through by text and pictures but you might better post this in the Iseki sub forum.
Sitting on the tractor you find 3 levers above floor level. 2 left, and 1 right.
Left1: H pattern: PTO speed selector, middle is neutral
Left2: up-down position: up= 2WD, down= 4WD
Right: this is not a handle but a rod-pedal : the diff-lock. You press it by foot while driving. (at moderate speed) to engage.
On your left hand side on the wheel arch you find 2 levers:
left one: 2 positions: high and low gearing. (low= creep)
right one: transfer gearbox:
-2nd speed: completely down
-3rd speed: 1 position up from 2nd
-Neutral: 1 position up from 3rd.
-1st speed: completely up.
Playing around with these settings should get you on the move.
Normal operation should be 2nd speed-High and then the gears with the gearstick.
If you are in Low and 1st or even 2nd speed and a low gear you will at idle barely see the tractor move. These are the creep speeds.
Hope it helps.
Hi peter,
Hope it helps.
Thank you for help ...
Actually I want to change the oil in engine and hydraulic system.
Do you know how litres is the engine oil capacity and gearbox, do you know which type of oil I must use for hydraulic system and gearbox and is they with different type of oils or gearbox and hydraulic system are with one type?
How can I check oil levels?
Thank you for answers again.
Regards: Peter
   / User and operating manual Iseki TL 2500 #4
Peter,
I have no idea on the cappacity in the TL2500.
In any case:
- 15W40 diesel engine oil should do it for the engine. (might want to go to a 10 grade in winter)
- the gearbox and hydraulics are 1 reservoir with a dipstick next to the gearstick and a drainplug on the bottom side of the transmission tunnel. On top of the tunnel you have a black +- 5cm diameter rubber plug: the fill hole .
Universal hydraulic-transmission oil can be used there. (i dont remember the exact type number but it was a common oil for tractors so your store should know) Expect somewhere between 15 and 30 liters of it to fill up. (The TL2500 has the TL2300-2500-2700 frame so i have nu idea how much it takes compared to the TL1700-1900-2100 frame)
1 thing on the hydraulic oil: if you dont know what is in, you better drain it completely. That means also from your implement cylinders and replace all with 1 type.
Mixing oils can do funny (read: expensive) things and you sometimes wonder how that much crap can get into it.
For your front axle you can put the usual axle oil. (EP90 if i am correct) or some just put there also the hydr-universal oil.
Thank you very much Tatra, this information is very valued for me.
2013 MACK CXU613 (A53843)
2013 MACK CXU613...
2013 PETERBILT 365 T/A DUMP TRUCK (A51406)
2013 PETERBILT 365...
Heil V-1722 28Yd Front Loader Garbage Truck Body (A51691)
Heil V-1722 28Yd...
2 - BOXES (A53843)
2 - BOXES (A53843)
2015 Peterbilt 579 T/A Sleeper Cab Truck Tractor (A52377)
2015 Peterbilt 579...
Adams 6 Ton Hydraulic Lime Spreader (A53473)
Adams 6 Ton...
