I am in WA state on 6 acres with alot of clay that I wan't to fill most all low areas with as alot of it holds water till late May & then some. front 3 acres is o.k. & is built up allready. Sand is cheap here & everything else is not. top soil being about 400.00 for 10 yeards, fill dirt aka clay as I allready have is 150.00+a dump load. I thought of useing sand & chip & maybe even leaves from local tree services as a dump spot. anything I should know about useing alot of sand as a build up material..? Never done it & is the reason I ask. I have installed a great open ditch system & is quite complex actually that works great & moves ALOT of water out of here allready.
Thanks Joe
Thanks Joe
