Used Pressure Washer -- what to look out for?
   / Used Pressure Washer -- what to look out for? #1
jas67
Platinum Member
Central PA
Kubota B7610 + Kubota G1800-S
I'm looking at a used 11HP pressure washer this afternoon. I'm not sure of the brand of the unit, but it has an 11 HP B&S engine on it.
Aside from just trying it out, and the usual things like looking at the engine oil, checking for leaks of engine oil, or water from the pump, what else should I check for?
Thanks,
Jay
   / Used Pressure Washer -- what to look out for? #2
Thanks,
Jay
There is a pressure test gage you can plug in to test pressure. About the max pressure you will see is when the relief cuts in like when the trigger is off. That is not you usable pressure, it will be lower. You can leave the gage plugged in, and plug the hose in after the gage, and you can monitor the pressure. Check for leaks on the engine, see if the pump has oil at the correct level. Oil in the pump should normally be 30 W. Should have about 5 tips. Should have a device to suck in bleach or cleaner. It can also be left in place. Always have water running through the pump before starting.
2016 KENWORTH T680 SLEEPER TRUCK (A52141)
2016 KENWORTH T680...
2016 WITZCO RG-35 RGN LOWBOY TRAILER (A50459)
2016 WITZCO RG-35...
1972 Baker 30ft Pole S/A Towable Trailer (A51694)
1972 Baker 30ft...
1990 John Deere 2955 Cab Tractor (A55218)
1990 John Deere...
2024 VOLVO VNL760 SLEEPER TRUCK (A54607)
2024 VOLVO VNL760...
