USED OILS
   / USED OILS #1
lilyperch
Herrick, IL
2016 Kioti NX4510 HST Cab Backhoe
Tried searching several ways. What are doing with all the used oils from maintenance of tractor?
   / USED OILS #2
There are many threads. Don't know why search didn't find them. IIRC many use for treating lumber, Trailer decks, fence posts etc.
   / USED OILS #3
Our county landfill accepts it free of charge, just dump it in a large tank they have in the recycling section that's before the scales.
   / USED OILS #4
Every state and community is different. Texas doesn't allow the sale or use of waste-oil burners/heaters. None of the dumps around here will take it. They won't even take oil filters if they see them. Most oil change service centers and auto parts stores will accept used oil with some volume limits. Best to check around locally. Or return it to the earth and pour it down a gopher hole. :)
   / USED OILS #5
Even Wally World will take it here. I normally collect it into a used milk jug and drop it off on my next trip there.
   / USED OILS #6
In Cali the auto parts stores do take it, though I haven't tried in years. 50 hour maintenance coming up, so I am starting to look for most convenient place.
Are you allowed to do burn piles in Illinois? That's another popular option (that I cannot do here in California).
   / USED OILS #7
I pour mine into a barrel and when it gets full the recycler comes and picks it up. You should be able to find a recycler in the yellow pages.
   / USED OILS #8
I give my fence post a good slather at the base. Then I give any extra to a friend with a oil burning shop heater. To valuable to not use it for something.
   / USED OILS #9
Anyone who sells oil in Ma has to take the used oil.
   / USED OILS #10
Walmart, Autozone, Advance Auto, and O'Reilly in NC will take 5 gallons of less of waste oil. I have a 5 gallon jug that I use. Don't make a mess in the stores and if you do... Clean it up. (even if you didn't do it) We want to have the service in the future.
2013 John Deere 824K (A52748)
2013 John Deere...
Split Weight & Wheel Weight (A50515)
Split Weight &...
2017 Ford F-550 Ext. Cab Valve Maintenance Vacuum Service Truck (A50323)
2017 Ford F-550...
2014 Nissan NV200 Cargo Van (A50323)
2014 Nissan NV200...
1996 Carolina Skiff 19ft Fishing Boat with Boat Trailer (A50324)
1996 Carolina...
2014 Ford Fusion SE Sedan (A50324)
2014 Ford Fusion...
