Used L3710
   / Used L3710
Well I had "Rhoda" the 3710HST Kubota, (my wife names all equipment) delivered today and now I cant wait for the ground to thaw so I can make my lot look like the Army firing range!
I guess its time to move over to the Kubota Owning/Operating forum /forums/images/graemlins/smile.gif
Thanks for all your replies.
Tex-
   / Used L3710 #12
Rhoda huh??
If you owned a Toyota, you could call it a Toyrhoda..... /forums/images/graemlins/smirk.gif
   / Used L3710
5030, that is a likely name if we got a toyoder.
Well, anyway, I was playing with Rohda this weekend and noticed that after a cold start she had white smoke out the exhaust for about 30 sec and I added throttle to about 1500rpm and it seemed to stop. Now mind you it usually has black smoke on the first few turns when starting, but this smoke lasted for a while. I am wondering if there is something wrong here or not. It is used with 460 hrs on her.
   / Used L3710 #14
You were playing with "Rohda" were you? Better be careful, your wife might get jealous. One thing about Rohda, you don't have to bribe her with trinkets to get her to work.
Anyway, you didn't say how cold it was when you started the 3710 or whether it was outside or in a heated garage or shop (like mine is).
Normally, diesels will puff a little white smoke due to incomplete combustion when the cylinder (s) are cold. They tend to sound like a bucket of bolts too. thirty seconds is a little long for a pre-heated engine (glow plugs) to white smoke. You might have a problem with the injector cups leaking.
Actually, the best way to find out exactly what is going on inside is to do a spectroscopic oil analysis If you have a heavy duty truck (class 8 diesel) outlet near you, like a Freightliner, Peterbilt or Western Star dealer, stop by the store, go to the parts counter and ask the counterman for a pre-paid oil analysis kit. Caterpillar has a really good one for about $18.00 retail. Follow the enclosed directions for obtaining a sample of your drain oil, mail it off in the neat plastic bottle and the analysis company will send you a spectra-analysis of exactly what is in your oil. That way, you will have a good idea of what kinds and substances are suspended in the oil, diesel fuel and anti-freeze included. We use it to monitor all of our tractors as well as our trucks. You will be able to tell if your cups are leaking by the fuel dilution percentage. Or, if it is antifreeze for that matter. (white smoke can be antifreeze too). There will also be percentages of lead indium, brass, bronze, steel, etc. We like spectra analysis because it will tell us when it's time to roll in a set of bearings or for that matter, if a head gasket is perforated. Minute amounts of anti-freeze can't be seen in drain oil. The antifreeze has to be in a large quantity in the oil to make it milky. The same holds true for diesel. For the diesel to effect the viscosity of the oil, well, at that point, you would need a re-build pretty bad. Whatever winds up in the combustion chamber, a certain amount will get by the rings and wind up in the crankcase. The oil analysis will show that.
Toro Workman HDX-D Utility Cart (A55787)
Toro Workman HDX-D...
2008 Hitachi PC228 (A47477)
2008 Hitachi PC228...
BUSH HOG 1815R1 BATWING MOWER (A51247)
BUSH HOG 1815R1...
RIGGING BOX W/ MISC SHACKLES, LIFTING CHAINS (A54757)
RIGGING BOX W/...
1996 Allegheny 35ft 25 Ton Flatbed Equipment Trailer (A51692)
1996 Allegheny...
