used kubota L2800
   / used kubota L2800 #1
little k
Marshall IL
L2800 & a 1970 4020 D
I bought a used Kubota L2800. This the first orange tractor I owned. Always had JD. This may sound stupid but where is the dip stick? I have looked on the right side where oil filter is. The only thing there is a black plug that will come out. No stick on it. Don't have a book yet. A reply Would be great. thanks little k
   / used kubota L2800 #2
I have an L2900 and had a hard time finding mine. If you are sitting in the seat mine is on the left side about in the center of the side engine cover. You don't have to open any of the covers to find it, it is just below the side cover and hard to see. I have to get down on my knees to see the hole to put mine back. Since my tractor doesn't use much oil I don't check it often.
   / used kubota L2800
Thanks for the responce. I looked on left side & still can't find dip stick. Will look harder. It has to be there some place. little k
   / used kubota L2800 #4
On my L2800 (2009) it is on the right side when sitting on the tractor. Locate the oil filter, look to the left past the fuel filter, the yellow/ mustard dot in my picture. The top is not very big.
L2800 w/FEL - 72" Land Pride rake
   / used kubota L2800 #5
Sounds like the stick is missing, should be attached to the "plug."
   / used kubota L2800
A man was tearing down a building & had a Kubota. He found dipstick for me. The top was broken off & it was stuck. thanks for the replies little k
Rhinox Mechanical 40 mm Coupler (A52384)
Rhinox Mechanical...
SAKAI SW502S-1 SMOOTH DBL DRUM ROLLER (A51246)
SAKAI SW502S-1...
2012 Ford Escape XLS SUV (A51694)
2012 Ford Escape...
40' High Cube Multi-Door Container (A50123)
40' High Cube...
(APPROX 24) 2" X 3" X 49" TUBING (A51247)
(APPROX 24) 2" X...
2025 Mower King SSRC (A50123)
2025 Mower King...
