Used Implement Pricing?
/ Used Implement Pricing? #1
PineRidge
Super Member
Northeast, Ohio
LS-MT242HC
I have a ghent in the neighborhood that has contacted me about some used implements that he wants to me to buy or sell for him. The following 3 implements are all 3 to 5 years old.
Land Pride post hole digger. It is either a 10 or 15 series with a 12 auger and two 6 inch augers.
5' box blade in nice shape, I could not see a manfacturer name but the color is red if that helps. It looks too new for a repaint it has 5 replaceable points & replaceable cutting edge all in good condition.
5' back blade in nice shape, I could not see a manfacturer name but the color is red if that helps. It looks too new for a repaint.
Can anyone give me an idea of what I should expect to pay for these items?
THANKS!
/ Used Implement Pricing? #2
I would be interested in 2 out of the 3 if you want...
The PHD & Box Blade are what I would be interested in...
Let me know...
Ducati996
/ Used Implement Pricing? #3
There is some difference in the heft of equipment and that would make a difference. You can buy a 5' back blade for 200 new! I would look at comparable new pricing and then cut it by 1/3 minumum.
/ Used Implement Pricing? #4
Depending upon the price and the build quality I might be interested in the back blade. I think the 5' box blade would be a bit much for much TC24d. You are close enough that it would make a nice Saturday drive.
/ Used Implement Pricing? #6
Condition, quality and features determine the worth of the items.
I sold an old light duty Speeco Rear Blade for $50 and felt fortunate to get that. The blade was very light and had minimal features, it basically adjusted to about a 30 degree angle each way. It did not reverse, it did not tilt, and it was pretty rusty. When I priced new blades I found blades from the around $100 up to $350 new, I purchased the one had the features I wanted, if I sell it, it will be priced based on the condition, quality and features.
I bought a used Befco 60" finish mower for $1100 that was in fantastic shape and easily would have cost several hundred more had I bought new. I felt I did well there.
A Land Price PHD is typcially a more expensive unit, but the series will make some difference in the resale price. $300 on the low end seems reasonable maybe as high as $500?
Box blade run the gamut of cheap to good quality, ditto the back blade. What features they have will help determine the selling price.
Does the back blade have tilt? Offset? Does it have a welded cutting edge or is it a reversable/replaceable cutting edge? If it is heavy and has multiple features it can probably sell for up to $200 used if it adjusts with pins instead of bolts.
Box scrapers can have reversable rear blades, or two sided rear blades, they can have welded cutting edges or reversable ones. They can have adjustable scarifiers or single position scarifiers, and they can be bolted in or they can be designed to be adjusted with pins. The box blade might sell for as low as $150 and maybe up to double that, depending on the original price and the features.
Just my thoughts on values.
/ Used Implement Pricing? #7
In a word -- eBay!
/ Used Implement Pricing? #8
jwstewar . . . I use a 60" box blade on the back of my NH TC24D and it is not too much of a struggle, the soil conditions I used it in was basically dry hard clay.
It works better on my Kubota B2910, but that tractor has more weight and more HP.
I've stopped the TC24D dead in its tracks using a 5' rear blade, but that was when it hooked too many granite cobble stones and the granite weighed as much as the tractor.
/ Used Implement Pricing? #9
Hello. I am new to the forum and have been reading posts with great interest for the past couple of weeks. At last a subject that I know a bit about. A new LP PHD 15 w/1 9" auger runs about $815. If it has a stand also, then add $50-100, because a new stand is around $115. Cheapest 6" auger you can get is around $100 new. If all the pieces are Land Pride, then each auger runs around $150 new; my LP 9" auger ran around $200 new; a 12 in would run maybe $240 new. LP diggers come with 5 yr gearbox warranty; you need to check on whether it will transfer and get original proof of purchase/delivery date if it does. I would go for 50% of new, assuming that it is all Land Pride.
/ Used Implement Pricing? #10
Ouch, that's an expensive PHD. I got a vassar to fit my BX2200 for $600 and I thought that was high....
Ron
/ Used Implement Pricing? #11
<font color="blue"> In a word -- eBay!
</font>
Generally speaking Ebay is still a seller's market. I can't believe the prices I see some of the stuff going for. I'm looking for a set of wheels to mount snows for the wife's new car. A set of 4 went for $135 + $120 shipping! Cheaper to buy them new!
Occasionally you get lucky (Picked up a service manual for my TC18 for $24.99 + $6 shipping).
/ Used Implement Pricing? #12
Jim,
I doubt if you ever tear up a standard duty 5' blade on your property. I have one I used on my TC18 that I got at TSC for about $150. Sure, the fit and quality is not great, but I move dirt and snow.......I don't care. I have one local to me that has a 5' with offset and angle (no tilt) for under $200. Another dealer that has Midwest for $200 angle only.
BTW you can use a 5' box blade as well.......I do /forums/images/graemlins/grin.gif
Just gotta watch what you do with it and how much you fill it.
/ Used Implement Pricing? #13
Yes. However, we have to dig postholes in extremely rocky ground. I could not penetrate more than 1 1/2" with a core aerator and 400# ballast tanks filled with water two weeks ago. Am waiting for a bunch of rain so we can aerate in the rain. My KS land is reclaimed mined land, and when we built two porches and one deck there we could not dig down further than 12" with a two man rental digger and auger. Returned the rental, got refund and did the rest by hand. Figure I will get my money's worth out of the 5 yr warranty if something goes wrong and that is my primary reason for purchasing Land Pride new. May be digging holes around 5 Dec, so will provide update then.
/ Used Implement Pricing? #15
</font><font color="blue" class="small">( Ouch, that's an expensive PHD. I got a vassar to fit my BX2200 for $600 and I thought that was high....
Ron )</font>
Ron......
Could you post a picture of the Vassar PHD and give us a little information on how you like it....... It might even be worth starting a new thread in the Kubota Owning/Operation Forum. Lots of us BX types here and we all crave information....lots of it......... thanks
/ Used Implement Pricing? #16
Will try to take some pics over T Day vacation. I've dug about six holes in the backyard (just practicing) and it seems to punch into our hard clay pretty well. I have the 9" auger.
I got mine as part of a package from my dealer and paid $600.
To me it appears to be medium duty.
Ron
Case Axial-Flow Combine Wheels NO RESERVE (A63118)
Case Axial-Flow...
Timpte 720 All Aluminum 7000 Tilt Trailer (A63689)
Timpte 720 All...
KMC 3pt 6 Row Peanut Reshaker (A64127)
KMC 3pt 6 Row...
2016 FREIGHTLINER CL120 GLIDER 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2016 FREIGHTLINER...
New/Unused Wolverine 3 Point Hitch Coupler (A65583)
New/Unused...
2012 Allmand Bros. Maxi-Lite SHO-HD Light Tower 20KW (A63689)
2012 Allmand Bros...
