Used Dump Truck Pricing Sites
   / Used Dump Truck Pricing Sites #1
Bucky4
Eastern suburbs of Pittsburgh
'03 L3130, '06 BX24, '11 RTV1100
Are there any sites similar to Kelley Blue Book, Edmunds or NADA, i.e. FREE, where you can investigate used dump truck pricing. (Small dumps, eg. F350, 3500, etc)
Thanks,
bucky4
   / Used Dump Truck Pricing Sites #2
I know it isn't exactly what you are looking for, but Truck Paper has some smaller dumps listed. Maybe that will help you in pricing them.
Truck Paper
   / Used Dump Truck Pricing Sites #4
Price varies DRAMATICALLY by year, condition, and mostly by season (more in spring/summer and less in fall/winter in northern climates).
I bought one about 2-3 years ago and just kept looking in my local papers ("Mini-merchant," gas station trader magazines, etc) until I knew a reasonable range for what I was looking at. I ended up with an older (1981) F350 that needed a bit of work to make it smoother...luckinly my brother-in-law owns his own garage and helped me a lot.
If you have a good truck you may just consider a dumping trailer...one less engine to maintain...just an idea
Peter
Thank you all for the info. I'll check out the sites, but in the meantime, this is the truck I'm investigating. Maybe someone can offer an opinion on the price or features?
'02 Chevy 3500 - silverado pkg., 6.0L V8, auto, a/c, AM/FM, cloth bench, extendable mirrors, 28k mi, Meyers/Diamond 8ft steel plow, 8ft dump bed w/full cab protection, central hydraulic system w/ 2 rear remotes, dual fuel tanks, hitch, toolbox, 1 owner.
Cab Condition Outside - very good, one small dent on pass. door, no visible rust
Inside - everything good except for some salt buildup and rust around the hydraulic system valves on the floor. Can't tell if it's causing the sheet metal under the vinyl mat to rust.
Bed - since the previous owner had a salt spreader on this, the bed, tailgate and hitch areas are very rusty. Usable, but not pretty to look at. Plow was in the bed, so I couldn't get a good look at it or the bed, but I did see some areas where the rust had started to flake off layers of the bed's sheet metal. A possible concern.
Tires - about 50%
Engine - started and ran fine
Brakes - seemed very good, no pedal vibration when stopping. Not sure if antilock is on it or if it works, because I didn't do any sliding.
Driveability - seemed normal, no noticeable problems.
Factory warranty on cab & chassis is good for another 6 months or 8k miles. New PA inspection. Asking price is $25,995.
Carfax gives it a favorable report. Only repairs mentioned are computer reprogrammed, fuel tank & fuel pump replaced and exhaust system replaced. The truck is clean overall except for the rust & salt areas mentioned.
Original owner unknown. Sorry, no pix at this time. Will try to post some later.
Thanks,
bucky4
   / Used Dump Truck Pricing Sites #6
JayC,
Thanks for the info on the site, I didn't know about it.
   / Used Dump Truck Pricing Sites #7
Glad I could help. Truck Paper also has a sister site called Machinery Trader. Here is the link.
Machinery Trader
MISC WRENCHES (A53843)
Toro Workman MDX Utility Cart (A51691)
Toro Workman MDX...
ECONOLINE TRAILER, INC (A50323)
ECONOLINE TRAILER...
RV Hitch (A50121)
RV Hitch (A50121)
2017 KOMATSU PC290LC-11 EXCAVATOR (A52706)
2017 KOMATSU...
2015 Chevrolet Silverado 1500 Pickup Truck (A53422)
2015 Chevrolet...
