Used Cub 3206 - What to watch for?
   / Used Cub 3206 - What to watch for? #1
Dougryan
Webster, NY
Cub Cadet 3206
Hi,
I've got my sights on a 3206 with about 450 hours on the meter.
Owner says it was maintained well and has not issues.
I know it's a solid tractor. Heavy... not a cheap big box cub or deere type of machine. I also know it's almost 20 years old...
So it may run fine, but parts still wear out. So, what should I look for when test riding it?
Any key issues that are tell tale red flags?
Thanks,
Doug
   / Used Cub 3206 - What to watch for? #2
Look for oil leaks. Hydraulic valve assembly is expensive. If it has the vacuum PTO engagement check that it operates smoothly. I had a 3235 (similar tractor) that blew a head gasket. Head bolts were never torqued down during manufacture.
Bob B.
   / Used Cub 3206 - What to watch for? #3
Hi,I have 2 ,3206 tractors,as the previous person said check for oil leaks,and make sure hydrolic oil level maintained at full do not run with low engine oil or hydrolic oil,other than that I have just under 1000 hrs on one of my tractors and I just sold my second 3206 with over 2000 hrs on it and 300 hrs on the engine rebuild,good luck!
John Deere 4 Row Cornplanter (A50775)
John Deere 4 Row...
2004 CATERPILLAR 420D BACKHOE (A51406)
2004 CATERPILLAR...
2025 Swict 72in Bucket Skid Steer Attachment (A55787)
2025 Swict 72in...
MISC TIRES (A54757)
MISC TIRES (A54757)
2019 GENIE GR-20 ELECTRIC VERTICAL MANLIFT (A52705)
2019 GENIE GR-20...
2007 Bomag BW120AD-4 Tandem Vibratory Smooth Drum Roller (A52377)
2007 Bomag...
