Used Comercial vs New Small Farm Tractor
/ Used Comercial vs New Small Farm Tractor #1
Crossroads
Westbrookville N.Y.
I am looking to buy my first TLB. I have rented TLBs before and my favorite was an ALLmand Bros TLB25D. I cannot afford a new commercial class but used Allmands or Teramites run bewteen $8-$13 K with anywhere from 400 to 1500 hrs. I would have to finance either of these two at 4.9 %.
Massey Fuergusson & Kubota are offering zero percent 60 months but again I could only afford a sub compact like a 2300 or BX-24. They would run about $16K
The Allmand or Teramite can lift about 1700 lbs at the bucket vs 600 for the small farm tractors. Breakout force is about 3 times greater on the commercail as well.
The tractor will be used for ditching and maintaining a driveway, landascaping unloading firewood, which either can do, although I live on a very rocky hill with high mineral soil.
I have a lot of stumps 24 " or greater to dig and a lot of rocks to move.
So the quandry
1) Buy the more powerfull tractor from a rental center used, with no warrranty, finance it myself, and hope no problems.
2)Buy the MF or Kubota new with 2 year warranty and zero percent financing, peace of mind, but may have problems with bigger stumps and rocks.
3)Prefer liquid cooled diesel vs air cooled gas because I have found diesels can be run at a lower rpm while working vs gas but not used one in the winter yet.
Any suggestion appreciated.
/ Used Comercial vs New Small Farm Tractor #2
You do pose a good question for your first post (welcome aboard, by the way).
WHen I think "commercial TLB", my mind goes to a Case 580 or a Ford 555, a bit different class.
Have you posted on the "construction" forum here? I'd want to know about the reliability of the Allmand and teramites. Also try posting on sites that use a lot of them. Landscape contractors etc.
To my mind, all the units you listed are a bit small for a steady diet of 24" stumps and larger rocks. Determination and lots of time can (maybe) git 'er done, but ... a larger unit could scoop with so much more authority!
jb
Thanks. Maybe I misspoke, I used the term commercial becuase those units I have seen used for constrcution, and rental centers.
I just spoke with a Mahindra dealer. He was quotoing about $23 K for a 3215 zero financing 4WD 3 yr warranty. So maybe I should rephrase.
I'm looking for the strongest most reliable tractor either 2 or 4wd, gas or diesel new with a good financing rate for $20K or hopefully less.
Thanks again.
/ Used Comercial vs New Small Farm Tractor #4
A 24 inch stump is a pretty big undertaking with a full sized backhoe. Have you tried to take out that size of stump with the Terrimite? I don't have any experience on that sized machine, so I'm sure it's possible, but I also know that I've battled with stumps of that size with my 555E loader backhoe, which has 80 hp.
Have you considered buying a compact tractor without the backhoe and using the saved money to rent something big enough to take out those stumps allot quicker and easier? Probably a 100 hp excavator would do it. Or hire it out to sombody with a large excavator that can pluck them out in just a few seconds. Get the right sized machine in there and he can do all of them in a day. (How many are there?)
One more reason to consider renting or hiring it out is wear and tear on your machine. Stumps are a pain to get out. There is allot of forcing going on that's not all that good on your backhoe. Sometimes they even break, especially with small equipment.
Good luck,
Eddie
/ Used Comercial vs New Small Farm Tractor #5
I would approach differently.
I would go used on a slightly larger tractor.
That Terramite and Allmand spec of 1700 lbs I find a bit tough to swallow, at least on the ones I have used. I cannot see myself buying one. Frustrated is usually the word that comes to mind when I have to rent one because of time or size constraints.
Over all, I think you would find a 24 - 35 tractor much more usefull. I would think you could find a clean used loader equipped tractor 4wd for around 15K
/ Used Comercial vs New Small Farm Tractor #6
Which Terramite are you talking about? The T-9 I rented had a 32hp Kubota turbo diesel in it, the smaller two models have air cooled gas engines if I remember right. Loader seemed to have good power, the BH seemed so-so, the unit seemed to have trouble climbing a mild grade empty. Although I was asking the HST for full speed ahead at full throttle. The T-9 seemed to be a better bulldozer than my CK30 is.
/ Used Comercial vs New Small Farm Tractor #7
Don't waste your time trying to take out many 24" stumps with any of the machines you have mentioned, hire it done as it will be a lot cheaper in the end.
/ Used Comercial vs New Small Farm Tractor #8
I think "where you live, or at least where the stumps are" is going to be the real answer to your questions. Around here, just about anything will take out a stump, some faster than others, but where there are rocks, there goes the time. You did mention rocks and high mineral content soil, so I have to assume your "not from around here". (Side note: My Dad is still "not from around here" and he has lived in the same place since 1967. Some folks never forget outsiders moving in, lol)
BTTOQ.
I would go with a bigger used tractor with loader and rent a backhoe or trackhoe with the money you save not buying a backhoe, unless you have already determined that the backhoe is going to be needed maintaining the ditch on the roadway.
David from jax
/ Used Comercial vs New Small Farm Tractor #9
So the quandry
IMHO, sizing your TLB for removing large stumps, even "a lot" of them, is a mistake. Unless you intend to get into the tree removal business, rent a stump grinder and get rid of those 24 inchers on your place once and for all. Spend your $$$ on a right-sized tractor for your other needs and on right-sized 3pt implements. Forget about digging out large stumps with a backhoe.
/ Used Comercial vs New Small Farm Tractor #10
Crossroads said:
*I have a lot of stumps 24 " or greater to dig and a lot of rocks to move.
*Hire this out.
1*I would be leary of buying from a rental place; This stuff gets rented out to every Tom Dick and Harry many of whom have little or no experience operating such equipment.
This stuff in many cases gets rode hard and put away wet and is abused.
2* better idea an like I said hire it done for the rocks/stumps.
3*fuel savings and more power is the biggie favoring diesels.
Winter is no problem for toady's modern diesel engines.
O percent is hard to beat.
In most case new at zero percent & used with a finance charge will be about the same monthly payment and total loan pay back.
There is no way I'd want to trade my BX 24 for a new Allmand or Teramite let alone a used Allmand or Teramite rental wreck.
/ Used Comercial vs New Small Farm Tractor #11
Thanks again.
Most reliable - anything Kubota or Deere.
Sure there are other brands that are "just as good as", but K and D are the standard others are rated against. While some disagree, the HST's are IMHO more reliable than the straight gear transmissions. Either way, it's like splitting hairs. All transmission parts are plenty stout these days and you should not have any issues. (if you go off of the K or JD, that won't hold quite as true....)
I would also strongly suggest you follow Eddie Walkers advice. He has popped a stump or two and has experience that can be counted on.
jb
Thanks for all the suggestions, I really appreciate it. The consensus seems to be don't base the machine on stumping big trees or carrying big rocks. In addition to maintaining my driveway, drainage ditches, and landscaping, that's what there is to do, so trying to find the most multifunctional machine is my goal.
Roots up here don't tend to grow deep, they run more horizontal just under the surface. I have stumped big trees with this Allmand although it's taken an hour or more. I'm just not a big fan of hiring anyone to do anything I can do myself. That said, I can always rent a stump grinder.
I'm going down to a dealer today to look at some Mahindras, bucket is speced at lifting 1400 lbs. The reviews seem pretty decent except for sluggish hydraulics on the bucket and zero percent & 3 year warranty is hard to beat.
I'll let you know how I make out. It will be nice to have a tractor on-site. When I rent, all week get's spent working because you're paying for the rental. I've started to hate the site of a backhoe because it meant working all week. It would be nice to have a machine where you can work a couple of hours here and there, instead of ruining your vacation digging all week.
Thanks Again
/ Used Comercial vs New Small Farm Tractor #13
Where is West Brookville, NY? I live in Alexander, NY and my 1st address in Alexander was on Brookville Rd. The house down the road used to have a sign on the house which said The Site of the Original Brookville Post Office. And so I understand it used to be a pony express station. Thus I always concluded there used to be a little town of Brookville there and it had been over taken by the town of Alexander, NY. I just found that interesting that somewhere else there is a Brookville, NY.
a
Westbrokville, N.Y. is 5 miles south of where 209 meets 17, about 15 minutes west of Middletown NY. I was in Buffalo for 3 years including the blizzard of 78. sure coulda used a FEL that winter. We used to go to a bar in Batavia, where we went to see Tallis with Billy Sheenan before he got big. Incredible shows in a small bar
I went down to look at tractors today,three different dealers, four different brands. I think I am going to go with the Mahindra 3215 TLB. Big ups to Rick at Marshall for offering a good deal. Thanks to all for your suggestions.
Oh yeah and, there's also Brookville and Old Brookville both on Long Isaland where i used to live.
Kevin
/ Used Comercial vs New Small Farm Tractor #15
I wish I could get more calls to pop-out 24" stumps with my CASE 580. It digs them out effortlessly.
Problem is, there's too many guys out spending 30K on shiny new small machines to do it themselves instead of hiring me for a few grand! :D
I've done 2 "stump jobs" in the past year. One job had some 36-48" stumps and some smaller ones. No big deal.
Makes nice extra side money for me and it's usually 8 or more hours in an air conditioned, comfortable cab. :)
