used CK20
/ used CK20 #1
southernAL
Dothan, AL
Kioti CK2510hst
Found a CK20 with FEL and 1300 hours, clean tractor, can pick it up for $8300, does this seem like a good deal?
/ used CK20 #4
Sorry don't really know. My brother bought a new one 1 1/2 years ago for $11500 if that helps.
/ used CK20
thank you oldpilgrim, yes it does. did his have the FEL on it?
/ used CK20 #7
$8,300 is a good price if the tractor has been maintained properly. They sell for $13-$15k new.
/ used CK20
ok went and looked at the tractor tonight finally. all in all it seemed like a nice clean tractor. didn't notice any leaks, and it didn't look all banged up. there was a couple things I'm concerned about. the first issue was the hydraulic bucket on the FEL, it didn't want to stay in position when you let off the joystick. It would drop down on its own. not sure if that is a cylinder problem or pump. it looked like it had plenty of fluid.
Second was the joystick. it had already been replaced before, but it just seemed like it needed to be greased or something, it was very "sticky", didn't want to return to the neutral position when you let off of it.
and Third was the 3pt hitch. it went up fine like it should, but would not lower down at all without weight being applied to it. Is this typical?
just wondering your opinions on what I found out. especially on the bucket issue.
/ used CK20 #10
The 3 pt hitch is normal to have to put weight on it to get it down.
The Joy stick is a problem I have never had on my ck20 hst.
/ used CK20 #11
This is not a pump problem, it is either a cylinder or valve problem, a decent hydraulic shop can fix it.
This is usually a bad joystick cable, they are approx $60/$75 a piece.
This is typical, turn the knob under the edge of the seat towards "rabbit"
As far as price, based on your description that doesn't sound too bad.
Is it an actual CK20 or a CK20S??
/ used CK20
Not sure what the difference in a ck20 and ck20s is. Could you explain? What could be causing the bucket to curl down on it's own? Leaking seal on the inside of the hydraulic piston? There was no evidence of a leak on the outside.
/ used CK20
Sorry just noticed where you replied amongst my post ha
/ used CK20 #14
Did the CK20s have the same injection pump problem for a couple years as some others? I would imagine at 1300 hours that if they did, it has been repaired.
/ used CK20 #15
7 or 8 years ago, I bought NEW ck-20S with Hydrostatic and a backhoe and fel. It has just over 1300 hours and has been a good tractor. I have maintained it by the book over the years. I had to replace a throw out beARING and a fuel cam AM OVER THE YEars. The dealer picked up the trctor (Michigan Iron) and fixed it up like new. You would be surprrized at the size and number of stumps that little tractor has dug out. I;m thinking it has several yers yet for me to work this fine piece of equipment.
rimshot
2007 Mack CV713 Granite T/A Pole Truck (A62679)
2007 Mack CV713...
2019 Ligchine Spiderscreed Concrete Screed (A59228)
2019 Ligchine...
DECKED TRUCK BED SLIDING TOOLBOX (A60432)
DECKED TRUCK BED...
New Holland TS6.110 Tractor with Alamo Boom Mower (A64047)
New Holland...
2017 Dodge Charger Sedan (A61574)
2017 Dodge Charger...
2021 Ford F550 4X4 Service Crane Truck (A62613)
2021 Ford F550 4X4...
