Rotary Cutter used bush hog
   / used bush hog #11
It's also hard to sell such a big thing should you have to. .
kind of a non issue... big mowers are for big jobs... 7' seems small compaired to my 10' or 15' mower. those who want big.. buy big if they can.
Another thing to consider is whether your loader raises high enough to pick it up for maintenance.
even if you just have to flip it up against a tree.. just about any tractor / loader should do that.. shouldn't be a need to completely lift the thing off the ground.
soundguy
   / used bush hog
Not worried about raising it high enough to work on. I will have hydraulic top link. The M5700, L3300 and ford 4500 all have FEL's also. Looks like I'm in the wrong area to buy farm stuff. Around here used stuff brings prices close to new. I don't even waste time going to auctions due to high prices. Anyhow the seller is a trusted family member he bought it from Disney World. Another family member worked there and remembered it, said it was used for heavy cutting that there other cutters was not rated for. He said it would cut at least 3" trees. They spare no expense in maintaining equipment so I doubt much is needed. I would think this sold for 3k or more new. The small rust hole is on top rear of deck where debris was not cleaned off. I bought it and should be getting in a week are so.
   / used bush hog #13
check the hole.. it might have been a drilled hole to allow water to drain from the deck... and then just enlarged from rust.
soundguy
CATERPILLAR CB-224C DOUBLE DRUM ROLLER (A52707)
CATERPILLAR...
2014 Ford Transit Connect Cargo Van (A54814)
2014 Ford Transit...
2022 CATERPILLAR 980 WHEEL LOADER (A51246)
2022 CATERPILLAR...
Grove 4x4 Rough Terrain Hydraulic Crane (A55851)
Grove 4x4 Rough...
2021 CASE IH 345 LOT NUMBER 12 (A53084)
2021 CASE IH 345...
