Rotary Cutter used bush hog
   / used bush hog #1
dirt clod
panama city and altha florida
Kubota L3300, m5700, case 580se
found a used 7' woods rotary cutter. Haven't seen it yet, but I'm told there is a small rust hole at the back where debris was left on top to rot. other than that is said to be in good condition. Is $1000 a reasonable price?
   / used bush hog #2
I like to pay no more than half of new price for used implements.
if it's an especialy mint implement that perhaps was bought and not used, used once.. or a leftover from another season.. I might go 80%.
If the price was right a small rust hole I could weld up in a deck wouldn't keep me from buying the hog.
search yer local for sale market and decide where that price lies base don the equipments condition and brand. ( 7' cutters fall in a weird area.. most are single spindle and single tail wheel, and actually take more hp to spin up than a dual spindle machine with perhaps 2 tail wheels.... still.. if you got the hp... etc.. )
soundguy
   / used bush hog
Thanks soundguy. I was hoping you would see this as you have a lot of knowledge on the bigger stuff. I would think this would be about 3k new as it is the heavey duty model. My M5700 should have enough power?
   / used bush hog #4
It sounds a little high to me :( $500 ) sounds better if it need a little TLC, and as long as your handy with the welder
   / used bush hog #5
I'm not familiar with your kubota model.. what's it's pto hp?
soundguy
   / used bush hog
57hp. I prefer to go slow when doing bush hogging. So I like to be on the large size for the cutter.
   / used bush hog #7
Price sounds hight to me as well, Your tractor will handle a 7' hog with no problem, I run a 6' with a 45hp L4200 and it does just fine.
-Mike
   / used bush hog #8
When a seller says there is a small rust hole in it I'd suspect it's a pile of junk. Now my experiences have turned me to that conclusin but others may have had better luck.
   / used bush hog #9
Price seems high to me as well. I picked up a used IM500 for $50 bucks. I haven't done a thing to it and it has mowed a lot of Sugar Maple saplings! Looks like (&*^&^ but does the Job!
Phil C.
   / used bush hog #10
Meh. I prefer a smaller device as I work in and around a lot of trees. A 7 footer would jack me up pronto. It's also hard to sell such a big thing should you have to. Anyway, I agree that a rust hole means it has been sitting in the weather for a long long time.
As you probably already know, the working parts of a rotary cutter are usually in fine order. It's the deck and blades that go. If you go look at this monster, be sure to get a good look underneath at the pan, the blades and the hardware. If you find that you have to put new blades on it and you need to demolish the nuts and bolts to do that, your bargain cutter just became no bargain. Another thing to consider is whether your loader raises high enough to pick it up for maintenance.
Case-IH 370 Steiger (A50120)
Case-IH 370...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
2015 Chevrolet Equinox 2LT SUV (A50324)
2015 Chevrolet...
2020 Lincoln Naultilus SUV (A50324)
2020 Lincoln...
Genie GTH1056 (A50120)
2001 J ODell 16ft Enclosed T/A Trailer (A51691)
2001 J ODell 16ft...
